It is currently Wed Jul 23, 2025 11:03 pm
PostPosted: Sun Mar 24, 2013 9:41 pm
That's why he is looking at extending the pushrod :)
Do the "late" ones have a different pedal shape?
PostPosted: Sun Mar 24, 2013 10:51 pm
Indigo is an engineer from memory so I don't think he has forgotten any mechanical wear points, and the indication is that it worked when originally installed. However, a few points that had been missed are the diameter of bundy tube and the length, both of which affect braking.
PostPosted: Mon Mar 25, 2013 4:07 pm
Yeah, miss read it. I thought he was saying the tin can had a longer rod, but what he was saying was that it will be longer when he extends it. :lol:
Dalmeny
PostPosted: Mon Mar 25, 2013 4:41 pm
How are the two clutches linked to the pedal if I may ask?
PostPosted: Mon Mar 25, 2013 6:19 pm
Fluid I'd guss, like they always have been.
Has the clutch ever worked properly? Are the brake lines the right size? Or is it just an issue with the amount of fluid the pedal is now expected to shift.
PostPosted: Mon Mar 25, 2013 6:26 pm
I ask as there's three master cylinders there. Two are obviously for the clutch pedal.
PostPosted: Mon Mar 25, 2013 6:29 pm
Mick wrote:
Brakes are about pressure. They don't need to move the pistons very far at all before they take up thereafter needing simply foot pressure to do their job. Clutches are more about volume. A clutch uses a lot of fluid to move a piston through a longer distance.
It barely manages this one slave cylinder as it is, let alone two pistons.
what if you sleeved slaves down to smaller size, you'd probably need to calculate exact size. Sometihng like master cylinder stroke = 100cc @ 25mm travel to slave cylinder = 50cc @ 25mm travel? Not actual amounts/distances but you get the idea. Turn up pistons/liners on lathe.
PostPosted: Mon Mar 25, 2013 7:57 pm
I hope it's just a small issue. I kept adjusting my cable clutch because the damn thing was too heavy, turned out the cable was siezing in the sleeve. New cable, like a new car.
I'd be surprised if both clutches were working simultaneously, surely the rear one is slightly delayed due to the length of the lines. Lots of stories about people shortening the lines to neaten up an engine bay, not realising they're a specific length to allow for the proper fluid volume.
PostPosted: Mon Mar 25, 2013 8:56 pm
I'm sorry but i fail to see what the length of pipe has to the with the workings of clutch/brakes.
Master cylinder displaces x amount of fluid, fluid doesn't compress so slave cylinder receives x amount of fluid. The inbetween doesn't matter so long as there is no air. Granted flexible lines should be kept to a minimum. But what does fluid volume have to do with the price of eggs in china? And fluid doesn't compress for a time delay to the rear cylinder.
I've been wrong about things before but i'm pretty sure this isn't one of those times.
PostPosted: Mon Mar 25, 2013 9:19 pm
The Twini has two clutch master cylinders, one either side of the brake master cylinder.
I have extended the pedal box to the right, including the rod that the normal pedals rotate on.
The clutch pedal is now fixed to the rod which now rotates, and has an extra arm on it to activate the second cylinder. The brake pedal still pivots on this rod as per normal.
As for the length and diameter of the bundy tube. In summary, what goes in one end comes out the other. Thus the length and diameter of the tube is irrelevant unless you look at the friction of the fluid moving through the tube, which would be minimal due to the low velocity of the moving fluid. The other issue with the tube would be if it expanded under pressure, which I doubt. If it did then the tube would suffer from fatigue failure over time. This is not the case as there is a lot of 40 year old tube still in use out there.
The flexable line could be an issue as this may expand under the given pressure. As the rear line is longer than the front, I have replaced this with a braded unit which in theory expands less.
PostPosted: Mon Mar 25, 2013 9:24 pm
Do you get any rocking in the cross connect bar? It may cause one rod to push up a little further than the other.
PostPosted: Mon Mar 25, 2013 9:30 pm
Mick,
Have checked this out with a dial indicator - minimal deflection/ twisting between the two.
I also swapped the circutes around to check this. It made no differance.
Open to any other ideas.
PostPosted: Mon Mar 25, 2013 9:52 pm
Is it both clutches that seem not to be working properly?
Could it be something as simple as all the flywheels & backplates being machined back to true, but not the corresponding amount removed from the posts to compensate? So you need *heaps* of travel to get the clutch to work (straps aren't level on assembly).
Just guessing based on what seems to be happening on both after lots of new parts?
Jacob
PostPosted: Mon Mar 25, 2013 9:53 pm
I would use 2 master cylinders of the exact same sort, as the bypass port height in the late one might be different to the tin can one.
PostPosted: Mon Mar 25, 2013 9:57 pm
Err Doc, he's using two tin cyls for the clutch, placcie one for the brake :mrgreen:
cheers,
Jacob
Users browsing this forum: No registered users and 111 guests
