Hi
Just wanting confirmation or clarificaction on cooling system workings please.
i picked up a diagram off web to assist.
(thanks to
http://www.2carpros.com/articles/how-an ... stem-works)
Question
1.on a mini system the fan blows instead of sucks into the wing area - where low pressure area assists take hot air away?
2. Heater matrix comes off the number 4 cylinder end. Ideally if no cooling matrix is installed (ie no heater) then this hose should return to the upper radiator to allow cooling before re-entering the head? Instead of just back to lower hose.
3. Blanking plug instead of thermostat. Is its purpose to slow down water to keep a similar operating environment (ie not create too much flow?)
I have heard it also stops water short circuiting the system, creating potential for cooler or hotter spots. Please can someone give some details
(i don't intend to run without a thermostat just curious)
Cheers Darryl
