It is currently Fri Aug 01, 2025 9:53 pm
 Post subject: Yella Terra rockers
PostPosted: Fri Mar 29, 2013 8:06 am
maybe already covered but the search doesn't help.
just found this video
http://www.youtube.com/watch?feature=pl ... YuZa2F0ZpM
and got interested
any experience with Yella Terra rockers?
http://yellaterra.com/products/car-perf ... Identity=4
somehow i like that they don't come in fancy colors
Rover 214 atm ....
PostPosted: Fri Mar 29, 2013 1:25 pm
I have them, they work nice. Bit loud kinda and they have been adjusted properly.
PostPosted: Fri Mar 29, 2013 7:39 pm
They look OK, probably are well made but how much are they?
Next time I buy any (having experienced both Minispares and Minisport ones) I would go for these- http://www.med-engineering.co.uk/catalo ... rocker-set
PostPosted: Fri Mar 29, 2013 9:13 pm
What are 'K lock nuts', that MED use?
PostPosted: Fri Mar 29, 2013 9:27 pm
K grade steel? Not sure but they look better than the sloppy hex ones Mini****** use now.
PostPosted: Fri Mar 29, 2013 9:32 pm
Thanks for that but I just did a bit of googling and found:
http://www.smithfast.com/klocknuts.html
A hex nut pre-assembled with a free spinning external tooth lock washer. The locking action is achieved when the nut is tightened against a bearing surface as the teeth of the lock washer dig into it.
I guess this is the one thing I have to learn each day! 8)
PostPosted: Mon Apr 01, 2013 1:09 pm
Where would you buy these yella terra rockers from? The website is not working
PostPosted: Mon Apr 01, 2013 10:27 pm
When I called them 2 weeks ago, not much change out of $1,100
PostPosted: Tue Apr 02, 2013 6:58 am
ive used yella terra products on a number of V8's. they make a good product, i have used them once on a a-series years ago. they still do make them you just have to ask im pretty sure from memory they are full roller rocker, the tip is roller and shaft bearing is roller, i think they make them as you need them. as its a very small turnover part, not like the V6 and V8 rockers they sell.
i hope this helps you KLAS.
yella terra address phone number as below.
Address: 232/236 Wickham Rd, Moorabbin VIC 3189
Phone:(03) 9555 5522
Hours:
Tuesday hours 8:00 am–5:30 pm - See all
Sunday Closed
Monday 8:00 am - 5:30 pm
Tuesday 8:00 am - 5:30 pm
Wednesday 8:00 am - 5:30 pm
Thursday 8:00 am - 5:30 pm
Friday 8:00 am - 5:30 pm
Saturday Closed
PostPosted: Tue Apr 02, 2013 7:37 am
many thanks for all the answers.
not sure if i will ever buy a set for an a-series, but i think they could look quite good fitted to my Rover 3.5l V8
Rover 214 atm ....
PostPosted: Tue Apr 02, 2013 7:39 am
I reckon for $1100 you could buy better rockers elsewhere for an A series.
Even Titans would be much cheaper.
http://www.avrclassics.co.uk/_-Titan-Fu ... ?pid=48052
PostPosted: Tue Apr 02, 2013 7:45 am
I've not used YT roller rockers on a Mini but I have got them on my Rover V8. Nicely made, full roller set up and needed to fit grub screws to ther oilways in the heads to prevent flooding the rocker covers with oil at high revs. Like somebody said, they are a bit on the noisy side, and they are expensive to buy.
Only issue I had (somewhat surprisingly) was breaking the end of a shaft at high revs where it overhangs the end pedestal. To fix this I made up some cradle shaft supports so that the overhanging ends can't flex so much.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
