It is currently Wed Jul 23, 2025 1:58 am
 Post subject: First Engine Build
PostPosted: Fri Apr 05, 2013 1:20 pm
I'm playing with the idea of getting a bigger engine for my mini.(998 currently).
Is it worth saving up and just spending the money for a fully prepped/built engine and having someone install it, or is it cheaper to have a go myself and buy something that needs a reco? Eg Miniparts in Croydon seems to have some for about $1500 as a starting point. (1275 A plus).
I've never attempted anything like this, so will be asking alot of q's if I do it myself. I'm not in a rush to get it into the car, so time is not a factor, but if it's going to save me a grand or more in the long run, then I'd rather give it a go.
Matt
PostPosted: Fri Apr 05, 2013 5:09 pm
I did half half.
I had someone rebuild the motor, then did the install myself.
Building a motor is an art form and requires some degree of skill.
Installing the motor and its various peripherals is relatively easy wrenching.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
 Post subject: 998 worked
PostPosted: Sat Apr 06, 2013 2:07 am
hi have just undergone the same process .
i bought a 998 with a bigger crank which takes it out the a 1100 motor
i think if your going to under take something ur self find some one who can over sea ur steps like a ex mechanic or good neighbour who know how to build and take your time and read and ask questions !!
good luck
Fried Ricer
PostPosted: Sat Apr 06, 2013 12:30 pm
Theres no black art to building a motor, You just need to measure everything, be meticulously clean and don't cut corners.
There's a very good how to here:
http://www.ausmini.com/forums/viewtopic.php?t=67980
Edit: I seem to remember it being a pictorial guide?
Having said that some of the specialist tools like the various micrometers will be expensive to buy for a one of job so unless you can borrow them it might not be economical.
