It is currently Sat Jul 26, 2025 11:15 am
PostPosted: Sat Apr 06, 2013 5:32 pm
Have managed to get window regulator working again without taking out quarter vent window, BUT can't get roller into channel ......
Does anyone have any ideas?
Thanks in advance......
Cooper S Mk2
Cooper S Mk1
PostPosted: Sat Apr 06, 2013 6:33 pm
Have you read these?
http://www.ausmini.com/forums/viewtopic.php?t=60640
http://www.ausmini.com/forums/viewtopic.php?t=69906
PostPosted: Sat Apr 06, 2013 7:08 pm
Thanks,
Checked them out as soon as I decided to fix the broken winder. Didn't want to remove all windows if possible, so detached regulator from the mounting, and managed to get it working - seems just jammed for whatever reason.
Found that there is a pivot plate that can be moved when you take out the 3 screws, so gave that a try and figured worst case, remove all windows as per posts if necessary.
I managed to unmount the pivot plate and set the roller in the track and re-assembled and lubricated everything. Works perfectly and saved heaps of work, so might be a useful tip for anyone with the same problem.
Cooper S Mk2
Cooper S Mk1
Users browsing this forum: slacko and 78 guests
