It is currently Fri Jul 25, 2025 10:14 pm
 Post subject: Timing cover oil seal
PostPosted: Thu May 05, 2005 6:20 am
I'm having some difficulties fitting the timing cover oil seal. Its the open (spring) side to the engine right?
Well it keeps popping out of its hole, is there a specific way of intstalling it?
PostPosted: Thu May 05, 2005 6:44 am
Yes the spring & lip go towards the engine. There should be an oil slinger next to the sprocket too.
I put a piece of tube inside the seal, and thump it in carefully with a BFH.
The seal and cover need to be dry and clean- if you use gasket cement it will slip around as you have found.
Seal is neoprene coated, doesn't need any sealer.
PostPosted: Thu May 05, 2005 6:51 am
Goodonya doc, answering questions at 6:40 in the morning. I knew you'll be here I was counting to have the question here when you login
The oil seal was hanging on the shaft with bits torn off. Still havent seen the oil thrower
PostPosted: Thu May 05, 2005 6:54 am
Oil slinger is a `flat' bit of metal with a hole and keyway in it. Helps keep the oil off the seal..
I'd find one, if missing. :wink:
double row chain one is different to single row.
ps, Mike, make sure you Loctite the crank bolt and balancer again, when you reassemble.. 8)
PostPosted: Thu May 05, 2005 7:20 am
No slinger - old oil seal is worn to the metal both front and back.
I think it'll have to forget the slinger this time - really want to put the car back on the road. I can always redo it all again in the future. Do you reckon the oil seal is just gonna survive less time without the slinger or is it just gonna perish pretty much straight away?
PostPosted: Thu May 05, 2005 7:27 am
Probably what happened is the seal and balancer were assembled dry. Always smear some oil or grease on the seal lips, otherwise it will `burn' when you start the motor. Takes time for oil to get there....
Yes it will work (until seal wears) without a slinger, pick one up for next time! :lol:
<edit> typo..
Last edited by drmini in aust on Thu May 05, 2005 8:10 pm, edited 1 time in total.
PostPosted: Thu May 05, 2005 7:32 am
Thanks again, Heur Doktor (I think its German).
PostPosted: Thu May 05, 2005 5:13 pm
Shite did I forget to put the Slinger On.. :shock: If I rember correctly the Old one was worn out with no notch left on it :!:
Also Cant say I put Grease around the inside of the seal :? My Bad..
Sorry Mate
PostPosted: Thu May 05, 2005 6:33 pm
You probably thinking of Herr, but actually it would be more like
"danke, mein arzt" and before you all go racing off, arzt=doctor.
 Post subject: Oi!
PostPosted: Thu May 05, 2005 7:57 pm
Well your heart seems to be in the right place 1310/71...BUT...I don't think the good Doctor would appreciate being thanked as someones behind.... :?
PostPosted: Thu May 05, 2005 9:54 pm
without the slinger on the chain doesnt get as much lubricant adn the bottom gear can wonder a bit and puts extra friction (heat ) on the seal causing it to wear out quicker.
make sure you put it ona dn put it the right way or you will burn out the seal in about 10 mins and you will have to do it all again.
sorry about the butt in but i ned to say things sometimes.
good onya kev for telling him he nees one.
baaie dankie doktor.
PostPosted: Thu May 05, 2005 10:35 pm
:oops: is all I can So..
Other wise it all German to me ...Ekkk
PostPosted: Fri May 06, 2005 7:57 am
And the winner today is minicranks. He gets the secret prize!!! Why? you might ask. Let me tell you why:
Well I've started at 5am yesterday and finished at 5pm (12hrs - I know - I guess I'm a slow worker but I had some complications along the way and then the alt, bottom support collapsed and I realised my dizzy is loose too etc, etc).
But we get to 5 pm, I've already ran the car with the new oil seal but without the radiator etc on for 5 minutes and checked for leaks and waited 1/2 hour and 5 mins again and check again and no oil - yeppee - so by five I've got the rad and everything on, coolant it and started running it to see where the dizzy is supposed to be sitting. Done that, its now 5pm I havent slept in 2 days, I'm exhausted but satisfied and guess what my little girl does as soon as I switch the engine off - yes pisses oil all over the f'in driveway (thats the driveway which was covered with newpapers before waiting for the oil to leak but I've just removed them). Donkey mein arse. My dad took a photo of the cracked brick where I punched the wall.
So that timing cover (uselessly chromed as if any one can see it) doesnt seem to like holding the oil seal in it. I would shove it in there and use a pipe to fix it inside but it just pops out in a minute or less. So the pulley just pushes it out no matter how much oil you use. Also had difficulties with extracting the pulley and fixing it back on so had to unbolt the engine mounts and jack the engine up and down. Finaly got the puley on the shaft, then lower the engine to allow clearance for it to move on the shaft and somehow got the pulley through the seal - but I reckon the seal just popped off again and is f'in around banging against the timing gears.
So minicranks was remarkaly close - exactly 10 minutes of operation.
Now I'm gonna have to do it right - anyone wants to sell us an oil slinger (double row chain), a timing cover, a metal fan (tropical or 4 blade) and a do it yourself Voodoo kit?
Oh and Gaf. its ok, I'll get back at you one day. And like Mrs Brady told mr Brady just dont do it to Marsha too
PostPosted: Fri May 06, 2005 8:03 am
I'll give you a timing cover, dunno if I have a slinger but I'll look.
My guess is the chrome plating in the hole won't let the seal get a grip. :cry: :x
WHY did BMC fit the bloody seal from inside- I'm sure early 850 etc had it fitted from the outside!
PostPosted: Fri May 06, 2005 8:17 am
Yea they did have it from the outside. - The chrome cover ran for a few years in this engine without leaking (too much) so there might be a trick to using it - but f'ed if I know - f'ed if I care. you cant see the chrome down there anyway.
Thanks doc, I'll Pm marcello he was selling some items, might have a slinger and a fan.
Good news though - the gears are much, much better now - the 4th is solid and the 1st is easier to engage. If it gets loose again - I'll just get myself a new clamp and\or a new shaft. Its still not like yours (feels like there are 2 elements of slackness - one in the remote to box link and a bit in the box - but it doesnt really bother me.
Users browsing this forum: No registered users and 112 guests
