It is currently Sat Aug 09, 2025 8:34 am
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: What's my problem
PostPosted: Fri Apr 12, 2013 2:10 pm
amongst many, but please excuse my naivety on this
My engine seems to be missing and I have what sounds like an little click from around my distributor every time the engine misses
is this my dizzy gone or is it something simple or is it something else and I'm hearing it wrong? It does seem to get worse when the engine gets warm
am I not running on all four cylinders (pun not intended!)
taaaaaaa
PostPosted: Fri Apr 12, 2013 2:25 pm
Could be a crack in the dizzy cap, or a faulty plug lead. Maybe...
Time for a tuneup at Lordy's?
PostPosted: Fri Apr 12, 2013 2:48 pm
I'd say Dizzy cap as well. Sounds like its sparking.
Matt
PostPosted: Fri Apr 12, 2013 3:07 pm
Just to add to what the above have said , get someone to start it up in the dark ,whilst you have a look around the dizzy area ,you should see where , if any sparking is going on .
PostPosted: Fri Apr 12, 2013 3:18 pm
thanks fellas!
now to try and find one - Graeme Lord doesn't have one :(
anyone have a spare they wanna part with cheaply please??
PostPosted: Fri Apr 12, 2013 3:20 pm
good idea! - will do later
PostPosted: Fri Apr 12, 2013 3:45 pm
SteveOB wrote:
thanks fellas!
You need to ID the dizzy or show us a pic.
Dizzy type is marked on the body. For a `68 or `69 Matic it's probably a 29D.
PostPosted: Fri Apr 12, 2013 4:34 pm
couldn't see any numbers on the dizzy body but it did say Lucas. On the cap itself had the code SCH-273 (or 278?)
any ideas?? cheers
PostPosted: Fri Apr 12, 2013 4:35 pm
Looks like a 29D to me.
PostPosted: Fri Apr 12, 2013 4:41 pm
ha ha, I'll take your word for it Kev!
now I just need to find one, as my youngest daughter wasn't too impressed with us sputtering round the Gong today on my errands :lol:
PostPosted: Fri Apr 12, 2013 5:59 pm
Could be condensation-
Pull the cap off. Wash it inside & out with WD40. Wipe dry with tissues.
Spray inside lightly with WD40 then refit.
Also check the points gap is .015".
 Post subject: Dizzy ID
PostPosted: Fri Apr 12, 2013 6:48 pm
That is the dreaded 29D Kev is correct. I have new caps for all other Lucas distributors except for the 29D. I will have a very good one thouigh if that is what you will need but by the time I post it down to you it is not going to be cheap. Australia Post have just put prices up again last week. Your leads don't look crap hot either!
"Let us remove your "SHORTS"
PostPosted: Fri Apr 12, 2013 7:01 pm
You could always bin that dizzy and fit a 45D, parts for them are more available and IMO they are better made.
If buying new leads, I find the Bosch inductive core ones are good- they don't increase resistance with age like the carbonized string ones (eg Top Gun) do.
[edit]
Bosch plug leads-
3 x B35Ri,
1 x B45Ri
1 x B30CRi (coil lead)
Available off the rack @ Supercrap, Repco etc for ~$5.95 ea.
PostPosted: Fri Apr 12, 2013 10:52 pm
Talk to minis plus, Lindsay has some... Not many, getting rare.
PostPosted: Sat Apr 13, 2013 11:04 am
So pull the roller door down or go out at night (when the blackness has come down)....an arcing dissy cap is fairly easy to spot then :!:
Heee hee or if no one is watching, throw a heavy blanket over you and the open bonnet... :oops:
