Sean1098 wrote:
NG wrote:
Yep ads a grease nipple.
get a needle about a 19 gauge pack with grease, put grease in it
And push it In the rubber and boom greased. Small closes back up
As its a tiny hole a 19.
Do you mean inject it directly through the boot itself? or to lift it up and grease underneath?
It injects through the boot. Makes a tiny hole which closes when you withdraw the needle.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
