It is currently Sat Jul 26, 2025 5:51 pm
 Post subject: door hinge gaskets
PostPosted: Wed Apr 24, 2013 11:57 am
question...
what material do you make your door hinge gaskets from?
- '74 Clubman Ute project
PostPosted: Wed Apr 24, 2013 12:02 pm
The stock ones are made of a heavily bituminous card. They're like a 1/8th paper material heavily soaked in a waterproof resin. I've seen a few cars with gasket paper in there and it usually isn't a pretty sight after a little while as the paper comes apart. The hinge gaskets aren't too expensive however.
http://www.minisport.com.au/prod161.htm
Rubber ones are out there, I think they look better, but I have no idea of how well they last as I have only used the paper ones on my cars so far.
PostPosted: Wed Apr 24, 2013 3:34 pm
I've used the rubber ones after a couple years they crack on the outside and look crap
PostPosted: Wed Apr 24, 2013 9:28 pm
Make some out of gasket card and spray with waterproofing - will last years (maybe decades if you're lucky).
Cheers, Ian
PostPosted: Wed Apr 24, 2013 9:31 pm
Icecream tub... cut to size works well. Choice of colours too, rofl.
PostPosted: Thu Apr 25, 2013 12:41 am
i think i like the docs method best. choose my gasket colour at the freezer section, eat the icecream and then make my gaskets from the tub.
