It is currently Wed Jul 23, 2025 12:21 pm
PostPosted: Wed Apr 24, 2013 8:49 pm
Hi,
I have what I believe to be a mid 70's dual circuit brake master cylinder that I am using on one of my projects,could someone tell me which outlet is for front and which for rear,eg,top or bottom.
It is not a stepped unit and both the outlets appear to be of the same size.Could you pls PM your reply.
Thankyou
Budget,what buget!
PostPosted: Wed Apr 24, 2013 10:55 pm
I'm no expert but I always thought both outlets were the same, it's up to the rear brake bias to limit the flow to the rear cylinders.....but wait until someone else confirms.
PostPosted: Thu Apr 25, 2013 6:33 am
Mods rock!
Bottom -> Fronts
Top -> Rears
It is important that they are done that way only.
PostPosted: Thu Apr 25, 2013 10:31 am
thankyou,I knew it was important which way it wen,I just didnt know which way it went!t
Budget,what buget!
PostPosted: Thu Apr 25, 2013 12:18 pm
What is the reason for it to go a certain way, dose one make more pressure than the other or is it a safety thing or something :?:
PostPosted: Thu Apr 25, 2013 12:30 pm
I don't know why (or if) the original clubby tandem cylinders need them this way, but that's how they came from the factory. The bore in both is the same, so it really shouldn't make any difference.
The later yellow tag ones that you can buy now need to have them swapped (top for front, bottom for rears). That's because they have a split bore, and the top bore is narrower, which means more pressure is applied at the front.
PostPosted: Thu Apr 25, 2013 4:19 pm
Mods rock!
Legally, You need more fluid for the fronts, so as they wear and need more fluid from the reservoir, it's there for the takin'
Those yellow tag things are illegal in Aust. I have no f&^%ing idea why they sell them when the correct one is still available new :roll:
PostPosted: Fri Apr 26, 2013 8:03 am
Why are the yellow tag ones illegal? There's one in my car...
Users browsing this forum: No registered users and 69 guests
