It is currently Sat Jul 12, 2025 8:49 pm
 Post subject: Brake hoses
PostPosted: Thu May 02, 2013 7:35 pm
Got new discs coming. I have overhauled and refurbished the front drum brakes including new hoses. And haven't even bled them - is there a big difference between disc and drum hoses - will I need new hoses for discs?
David L
PostPosted: Thu May 02, 2013 7:53 pm
I believe originally they were different lengths, but that these days they are commonly sold as the longer length to suit both types.
Or maybe they were always the same length, but what is on the car should be fine.
PostPosted: Thu May 02, 2013 7:54 pm
Disc hoses are a little longer. It's more common than not however to get disc hoses these days, so check to be sure you haven't already got the longer type already by chance.
PostPosted: Thu May 02, 2013 8:32 pm
Just did some checking and drum are 30cm and disc are 27.5cm - ill have to measure what I've got.
David L
PostPosted: Thu May 02, 2013 8:56 pm
Drum hoses (being longer) when used with discs can rub on the tiebars. But a bit of judicious hose rotation fixes that.
PostPosted: Thu May 02, 2013 9:04 pm
I thught it was the other way around, but there you go...
thanks Kevin
PostPosted: Thu May 02, 2013 9:28 pm
The Mini King
At one stage in Australia the hoses were superceed to the one Number, and some people only sell the one length Hose, Mini King offer both hoses Long = Drum
Short = Disc
PostPosted: Fri May 03, 2013 11:51 am
John can you PM me the price of two short ones to 4563 - Thanks
David L
