It is currently Tue Jul 22, 2025 3:24 am
 Post subject: Looking at a 1275......
PostPosted: Tue May 07, 2013 3:48 pm
Hey guys well I am looking at a 1275 engine and have a few questions....
1. Is buying a non complete engine viable??
2. Apart from the head do there seem to be any other major parts missing??
3. Is my 73 van pudding stirrer compatible with this engine?
4. Is this a fair price for what's there or should I wait ( not made of money don't want to waste on a heap!! )
5. Major Things to look for if i inspect....
Cheers guys jaymie
PostPosted: Tue May 07, 2013 4:00 pm
Depending what is in that little orange box, lots of little things missing, little things all add up to a very big bill if you have to buy them new or reconditioned.
Example:
New 1275 Primary gear £98.00 from Minispares
New idler gear £89.99 From minispares
Crankshaft Woodruff Key £4
Cam is missing
Pushrods $80
Timing chain sprockets
Rocker cover, engine beathers list goes on and on...
etc etc etc
Don't let it turn you off buying it, just warning you that it all adds up if it ain't there!
Lillee - 1969 Morris Mini K
PostPosted: Tue May 07, 2013 4:01 pm
There's plenty of things that will come across external to the engine, but there are many things to watch out for which will add up the end cost.
External parts like the clutch, alternator, dizzy, and many nuts and bolts will come over, but you will need new timing gears, I can't see a primary gear there, and of course the cost of the rebuild. Head studs, higher spec clutch pressure plate and a cleaned radiator. Dizzy recurve, and check the caps match the block, there are numbers on the caps which shouldmatch the same stamped numbers on the block. If not, then the cost of machining will go up by $$$. Also, ensure the drop gears are there somewhere.
PostPosted: Tue May 07, 2013 4:05 pm
Yeah that's what i thought.... Not in a hurry just not many come up in SA but would much prefer to get a complete engine if I had more of an idea of all the little bits that matter it would help ( don't want to get jipped).... Never pulled down a mini engine..... Only other makes..
In saying That though cheers for your insight very useful
.... 1977 Leyland Mini S .....
.... 1972 Leyland Clubman .....
.... 1973 Leyland Mini Van ....
PostPosted: Tue May 07, 2013 4:25 pm
Just notice it does say all other parts/etc saved so might be worth a message and see if everything can come with it. As has been said above or is it a case of what you see is what you get!
1978 Leyland Clubman S
PostPosted: Tue May 07, 2013 5:31 pm
I see small journal crank and rods. :)
PostPosted: Tue May 07, 2013 5:35 pm
Really? I can't speak of the crank, but small journal rods have caps that are bolted on at an angle to the rod centerline. These are not..?
PostPosted: Tue May 07, 2013 5:38 pm
TK
Posted: Tue May 07, 2013 5:01 pm Post subject:
is that good or bad and if it has been sleeved does that make it weaker??
or am i better off just putting oversized pistons cam work etc in my 1100
and can i put twin 1 1/2's on my 1100?
PostPosted: Tue May 07, 2013 5:43 pm
No Mick, it's small BORE rods are as you say.
Small journal 1275 rods are either S rods or Midget rods (which look the same) without the big ugly lumps on the caps that later 1275s do.
PostPosted: Tue May 07, 2013 5:54 pm
The crank looks a bit manky! :?
PostPosted: Tue May 07, 2013 6:01 pm
D'oh! Of course...
PostPosted: Wed May 08, 2013 3:56 pm
Found out the engine number is 12YD TA H..... Correct me if I'm wrong but is that not a leyland gt motor not a morris 1100S
PostPosted: Wed May 08, 2013 4:06 pm
Morris 1100 S, not Clubman GT
PostPosted: Wed May 08, 2013 4:09 pm
Oh ok I stand corrected :?
Can u tell big or small journal for sure from the number??
Some lists on the web might say it's GT, but they are WRONG. It's a Morris 1100S, early one with small journal crank & `S' rods. (better for performance builds than the later big journal motors, IMO.)
Users browsing this forum: Majestic-12 [Bot] and 102 guests
