It is currently Sat Jul 26, 2025 12:16 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: dizzy
PostPosted: Fri May 10, 2013 1:11 pm
slide wrote:
I use Scorchers in all my cars, not exactly cheap but well made using Bosch Holden/Ford parts assembled by Performance Ignition Services
This lot Correct
http://www.performanceignition.com.au/home
Do you usually supply your own Distributor as in the body to
Performance Ignition Services or they can supply I'm assuming Good S/H useable Australian made bodies
Shafts?
PostPosted: Fri May 10, 2013 1:13 pm
Any of you guys ordered/used the new Aldon, the Amethyst I think it's called? I'm interested in it's potential for mappable ignition in a forced induction set up.
I like that it's a complete set up in a simple package. I like the look of a well done set up like Specialist Components, or Slo998's, but they require more work I would think.
"Speed has never killed anyone. Suddenly becoming stationary... That's what gets you" Jeremy Clarkson
"I'm sure there are people who will say that their mini is not fast, not cheap and not reliable!"
