slide wrote:
Ok, called into Kent on way to work this morning. Still all closed up but there are a couple of notices stuck on the front door.
‘Warrant of Distrain’ – anyone know what that means?
‘Notice of Termination and Re Entry’ – which I gather means termniation of the lease and denial of re-entry.
Looks like they have not paid the lease for two months and owe $18,750 to Olatest Pty Ltd. There’s the name and address of a Subrosa Commercial Agency, who from their website appear to be private and commercial investigators.
OK.... You will need to get hopping!
A
Warrant of Distraint is a mechanism whereby property owners can sieze goods in a property they own to potentially sell at auction towards gaining restitution of monies owed to them.
From what I understand in South Australian law (which isn't much as I've never practiced there), you have five days from the issue of the Warrant to make claim against the property owner for goods you have a prior interest in.
Clearly you have a prior interest in the gearbox you left there and you should now make immediate contact with Olatest Pty Limited. The first port of call for this will be via their Agents, the Subrosa Commercial Agency.
Unlike a Receiver/Manager, they have no right to collect any monies you might owe Kent Brake & Clutch for work they may have to date done on your gearbox. That is a different transaction, and even if you manage to collect your gearbox, you will still owe that money to Kent (assuming they have done the work?).
Rather, with Olatest/Subrosa, it is simply a matter of proving you have prior rights in relation to the gearbox. i.e. You own it and the only reason it was with Kent was because they were to perform services on it.
How you prove ownership is of course possibly difficult, however failing you having for instance a quote or receipt from Kent that refers to your gearbox, I'd suggest simply doing Statutory Declaration and get that witnessed before a JP and try using that?
Stat Dec form for SA
here
Good luck! If you act carefully, quickly and reasonably you should have no problems. The Landlords dispute is with Kent Engineering and not with you. Your gearbox will be of no interest to them.
David
