It is currently Sat Jul 26, 2025 6:30 pm
PostPosted: Tue May 14, 2013 9:58 pm
Greetings All.
The brake booster I have is missing the rubber diaphram.
It's a Mk1 vh44
It has a PBR 260550 slave cylinder.
Where can I source a new diaphram? Is there a part number I can google? I have a Mk2 booster which is the same hydraulics, but with a larger diaphram (Protex 40-10)
Is there a parts site or list somewhere I can use?
Alex
PostPosted: Tue May 14, 2013 10:01 pm
Very easy to get.
Hoppers Stoppers will have them, but they're just one name of thousands of suppliers however.\
Great website however. Its like wiki for brakes.
http://www.hoppers.com.au/
PostPosted: Tue May 14, 2013 10:14 pm
Thanks Mick.
Had a look at their site. Will have to email them.
Alex.
PostPosted: Tue May 14, 2013 10:43 pm
VH44's were on mk2 mini's and GT's. mk1's had Lockheed ones.
Unless there are two types of VH44Ja boosters (but im 98% sure there isn't)
I think the diaphragm went in mine too, so good thing to know where I can get em. Cheers Mick
PostPosted: Tue May 14, 2013 11:26 pm
Mick.
Just went out and had another look.
They both have PBR 260550 slave cylinders. They are exactly the same. Under the little filter grill, they both have VH44-4 in the casting.
The steel chambers both have PBR stamped on them.
The only difference is that one is 7&3/4 inches and has a diaphram rubber (Protex 40-10)
The smaller one is 6&1/4 inches and missing its rubber diaphram.
Nothing has Lockheed on it?
Alex.
PostPosted: Wed May 15, 2013 7:32 pm
Your larger 7.75" unit is your VH44 (7.5" Diaphragm). This is the one to rebuild.
I'm not sure of the other smaller unit. VH40 units are larger at 9"
PostPosted: Wed May 15, 2013 9:20 pm
Mick.
I sat the larger one where they usually sit in my 850. There's not enough room between the engine and where it should sit?
Took a couple pics.
Alex
PostPosted: Wed May 15, 2013 10:03 pm
The measurements tell me different, but I may be wrong. The larger one is a VH40 with the smaller unit being the VH44. Similar in construction, but the larger unit brings more pressure to bear on the brakes. Too much perhaps for a mini, hence the 44's are the ones we usually use.
PostPosted: Wed May 15, 2013 10:11 pm
Doesn't the bigger one belong in the Landcrab?
PostPosted: Wed May 15, 2013 10:30 pm
Yes.
That's where I started, then wondered off. The larger one was out a 1800 at the wreckers (why?) becuase it was there. I then thought it was possibly Mk2 and the small one Cooper.
Anyhow, I'm going to clean up the small one and visit a place in Adelaide called Power Brakes. I've been to I need a VH44-38 diaphram rubber.
The slave cylinder on the larger one is in perfect condition. I'll check the cups and use that with the smaller chamber.
Cheers all.
Alex.
