It is currently Sun Jul 27, 2025 3:56 am
PostPosted: Tue May 14, 2013 12:56 pm
Hi
Just changing over the breather arrangements on my 1310. I have a timing cover breather venting to air or catch can ( if track day), catch can is always unpressurised - and a rocker cover breather(RCB)
old system connected RCB to one of the HS4 carbs and blocked the other carb hole.
new model - RCB connects to both carbs with a y piece ( no PCV) valve)
i had the carbs off and on resetting idle noted a significant drop off of idle with oil cap off (vented) - not too much of a surprise but
checked vacuum with palm of hand over oil fill - and it is quite strong
my question is if the vented oil cap is not letting in enough air - will the rocker breather start to suck air from the carb tube?
i know this situation is at idle with a high vacuum and could reverse at higher revs? but wondered if there can be too much vacuum??
 Post subject: Vacuum
PostPosted: Wed May 15, 2013 1:07 pm
Vacuum also helps keep the oil on the correct side of the seals. Pressure will push oil out.
"Let us remove your "SHORTS"
PostPosted: Wed May 15, 2013 2:32 pm
I run a vented cap on the 1360 and an unvented one on the 1412 stroker. Vacuum is not a problem, whether running to the SU vac port or a manifold PCV valve and a Dellorto.
As said above the vacuum helps keep the oil in, on a road car anyway.
If there is NO vacuum under these conditions at idle, your rings and bores are past it.
Users browsing this forum: JM1275 and 84 guests
