It is currently Sat Jul 26, 2025 1:02 am
PostPosted: Thu May 16, 2013 7:00 am
Standard cooper s motor. Standard factory rocker cover. Standard factory style vented (taller) oil filler cap.
Oil filler cap contacts bonnet crossmember when bonnet closed.
If anything my bonnet is a little high along the rear edge rather than flush with the scuttle panel.
Is this a common issue?? Suggestions/solutions appreciated.
Cheers.
PostPosted: Thu May 16, 2013 7:17 am
If this a new issue or something that's existed for a while?
What type of engine mounts have you got?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Thu May 16, 2013 12:59 pm
When I fitted the taller (correct) vented cap it became an issue although i took a while befor i realised it was rubbing. The non vented just fits I think. When I first got the car it had a fancy rover style alloy r cover and large Cental flip cap and it also contacted.
Re the engine mounts I don't know what I have. Are some thicker?
Users browsing this forum: No registered users and 111 guests
