It is currently Sat Jul 26, 2025 1:09 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 16, 2013 4:35 pm
the injectors (and ECU programs) are desingned to work with the factory set up. not with a modyfied engine.
the factory carb and dizzy won't adjust itself to new engine specs, why should a injection system should do that? :wink:
Rover 214 atm ....
PostPosted: Thu May 16, 2013 4:38 pm
Nope it's because there are only 2 inlet ports in a 5 port head and many compromises were made to get injection to work at all with 2 injectors.
It was done for emission reasons, not to get HP.
Gets good fuel economy though- if you're into that kind of thing.
Mine uses 6 l/100km average. Best mini I've had for that.
:lol:
PostPosted: Thu May 16, 2013 4:51 pm
Yup, lets take the supercharger out of the question. Too expensive.
I'll have to keep the injection because I don't want issues with roadworthy.
bore to 1360, raise compression to 11:1, bigger inlet and exhaust valves, ported head, change cam, 1.5 rockers, LCB extractors, cat back exhaust, K&N (or equivilent) filter. Possible new pump, fuel pressure regulator.
Looks like i'll have to go this direction.
