It is currently Fri Aug 01, 2025 1:38 am
 Post subject: Help identifying speedo
PostPosted: Tue Jun 04, 2013 5:42 pm
Hi guys this speedo came in a box of spares with my project just wondering if its correct for my 68 minimatic or if I should chuck it into the for sale section ?
Jarrad
PostPosted: Tue Jun 04, 2013 6:18 pm
It's a mini k speedo from around 1969 on! :)
PostPosted: Tue Jun 04, 2013 6:59 pm
It looks the same as was in my 3/70 matic.
PostPosted: Tue Jun 04, 2013 7:20 pm
So if its from a mini k what style should I be looking at for a 68 matic or would they be the same ?
PostPosted: Tue Jun 04, 2013 7:24 pm
Same.
Only difference was the 69 on `matic had a Mk2S speedo binnacle, with temp and oil pressure gauges.
PostPosted: Tue Jun 04, 2013 9:24 pm
Thanks for the help guys
PostPosted: Tue Jun 04, 2013 9:31 pm
I thought a deluxe speedo was like this? Slightly different as it has central white rings and white needles and were Smiths UK made?
https://www.google.com.au/search?client ... ly9sGZM%3A
PostPosted: Wed Jun 05, 2013 3:51 pm
That is not like any Mini K speedo I have ever seen.
Filter, Ignition, High beam and Oil light windows are not correct.
Mini K only had High beam and Ignition light Windows....
It is from 69 or 70 but is not from Mini K.....
PostPosted: Wed Jun 05, 2013 9:25 pm
The Mini King
My Guess, Australian Made Mini deluxe speedo
PostPosted: Wed Jun 05, 2013 9:35 pm
Which would make it late Deluxe- around 1968? Would it then be correct for a 1968 `Matic?
PostPosted: Thu Jun 06, 2013 7:20 am
I've just compared it with photos I have of a very original mid to late 68 mini matic and it is fitted with the same speedo.
I'll get a photo up if I get a chance.
PostPosted: Thu Jun 06, 2013 3:19 pm
The Mini King
Yes it would and early 1969 models (pre June )
I am not sure however if the RPML is the same
PostPosted: Thu Jun 06, 2013 9:39 pm
The Mini King
looking at the last photo it has a ink stamp on the back the part number is often
in that stamp I would be very interested in knowing the part number if it is possible
to read it
PostPosted: Thu Jun 06, 2013 9:51 pm
Wouldn't it be nice to have a detailed picture of each of the speedos used on Australian Minis/Mokes showing the model and year they were fitted to?
... or does this exist somewhere already?
The Mini King catalogue lists the parts numbers but not a picture of each.
PostPosted: Thu Jun 06, 2013 10:15 pm
I can get a photo of the part number stamp tommorow for you John
