It is currently Wed Aug 06, 2025 6:54 pm
PostPosted: Sat Jun 08, 2013 10:03 am
Thought I would start this thread as a search did not turn up a lot and it must be a hot topic people are interested in.
Coolant Capacity - 3.6 Lt
Two questions.
1. What was the original formula for Aussie minis?
2. What are people using now ?
"Boris" - '69 Cooper S Mk 2
PostPosted: Sat Jun 08, 2013 10:10 am
Castrol Anti-Freeze Anti-Boil
It has all three I am looking for in a coolant, anit-freeze, anti boil and corrosion inhibitors. And there's a big rule about mixing coolant brands, so when I walk in to buy my coolant after two years, I helps me to know its a single well known brand.
http://www.are.com.au/feat/techtalk/coolants.htm
http://www.are.com.au/feat/techtalk/horror_pictures.htm
PostPosted: Sat Jun 08, 2013 10:15 am
Nulon ethylene glycol concentrate 25% / tap water 75%.
PostPosted: Sat Jun 08, 2013 10:19 am
i use tectoloy concentrate
PostPosted: Sat Jun 08, 2013 11:35 am
I use any current ehhylene glycol type concentrate, about 25 :75 but
are there 'track rules' which stipulate using a non slippery type.. i have heard it mentioned to use non glycol if going to the track.
one example is http://www.penriteoil.com.au/products.php?id_categ=6&id_products=98 i think it used to be called syn 10???
PostPosted: Sat Jun 08, 2013 11:50 am
FNQ wrote:
.... are there 'track rules' which stipulate using a non slippery type.. i have heard it mentioned to use non glycol if going to the track.
I've been using the Penrite 10 tenths coolant additive for many years in various competition cars (including alloy and cast iron engines). It has a red colour rather than the glycol green and seems to do the job of corrosion inhibitor and coolant wetting agent very well.
Curly
PostPosted: Sat Jun 08, 2013 3:18 pm
+1
But 1/3 concentrate to 2/3 tap water
1963 Morris 850
PostPosted: Sat Jun 08, 2013 7:01 pm
Nulon Ultra Cool non glycol concentrate mixed with demineralised water and a bottle of Redline Water Wetter.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
 Post subject: Coolant
PostPosted: Sun Jun 09, 2013 1:38 pm
I have done many electrolysis tests on various Coolant additives. The Toyota Long life (Red) is by far the best and the only one I would use. Perhaps not the cheapest but you get what you pay for.
"Let us remove your "SHORTS"
Users browsing this forum: Bing [Bot] and 82 guests
