It is currently Wed Aug 06, 2025 2:15 pm
 Post subject: 1970 Mini K gearbox
PostPosted: Tue Jun 11, 2013 7:23 pm
Hi All, I am a bit of a way off needing the gearbox back in, (I am just starting the rust repairs at the moment) But I was wondering, the 1970 K should have the remote gearbox? Am I correct? mine was fitted with a rod change with inner CV's and I also got a spare rod change (and a spare 998 with a anti smog head). I am trying to make it as original as I can, but I would like peoples opinions on whether the rod change or remote box is a better item? If the rod change is a better box, I might stick with it. (still keeping the hydro and the 1100 though) :D
Thanks in advance.
Current 1970 Mini K - full resto happening - finished and on the road since 10/2020 :)
2001 Falcon AUII XL 1 Tonne styleside ute
Mini History
1963 - 850 - wish I still had it
1965 - 850 - was an unfinished project, gone
1972 - Clubbie
PostPosted: Tue Jun 11, 2013 7:32 pm
High heel ninja
Yes, a mini k has a 4 synchro remote box, case no 22G1128, with rubber uni joints.
Doogie
PostPosted: Tue Jun 11, 2013 7:37 pm
Remote change is the better product IMHO.
But you may find the 'box Doogie mentions a bit hard to come by.
PostPosted: Tue Jun 11, 2013 9:09 pm
Thanks guys. I will check around and see what I may be able to find. Still have some body panels to buy first.
Mini History
1972 - Clubbie
PostPosted: Tue Jun 11, 2013 10:23 pm
I would use a 4 synchro remote box.
But unless you are hell bent on originality, I would use the pot joints. They are more durable then the rubber U/Js.
PostPosted: Wed Jun 12, 2013 12:09 am
Put a 5 speed A+ box in... Best thing you will ever do
Users browsing this forum: Bing [Bot] and 79 guests
