It is currently Fri Jul 18, 2025 10:59 pm
Post new topic Reply to topic  [ 236 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 16  Next
PostPosted: Tue Jun 11, 2013 5:34 pm
Looks like a great place to start from! Envious of how few panels there are on a moke.
1978 Leyland Clubman
PostPosted: Tue Jun 11, 2013 10:09 pm
Sweet find....how much? and I'm guessing this one is off the the sand blasters to pick up where the old one finished?
PostPosted: Wed Jun 12, 2013 6:27 am
There's a lot more work if you sand blast it. Clean up the areas that need doing and get or painted. I think if you get it blasted again you'll end up getting another quote for 20k to paint it again.
I've had a few minis blasted and regretted it each time
Life's a garden.... Dig It!
PostPosted: Wed Jun 12, 2013 6:32 am
Die Die Die!!
This one has had the panel work done by the panel shop I bought it off of, I believe it's rust free so I won't worry about sandblasting this time,
Should have a quote from them tommorow
PostPosted: Wed Jun 12, 2013 10:09 am
Nice shell, thats a lot cleaner
Can i ask why you regretted getting them blasted? What medium was used, sand?
1963 850 - laid up
PostPosted: Wed Jun 12, 2013 6:21 pm
Its like a barn find!!
PostPosted: Wed Jun 12, 2013 9:33 pm
I've only ever had bead blasting done, and it just takes a car right back to where it doesn't need too be. Get the bits that need doing blasted not the whole thing! If you get the whole car done you have to re-bog and shape a whole car, if you identify the bits that need doing cut them out and sand them back.
Even if its blasted, it will rust again eventually nothing is going to stop it. If its started to rust its in the steel and you can treat it as much as you can but it'll eventually surface
PostPosted: Fri Jun 14, 2013 11:38 am
Die Die Die!!
question ?
will a windscreen surround from a 1974 fit my new green moke (1982) ??
also does anyone have any side panel top covers ? or know where i can aquire some ?
PostPosted: Fri Jun 14, 2013 5:32 pm
No, yours is the later 3 bolt style (designed to withstand the higher speeds of the 1275). Could be made to fit, but you can buy a new stainless steel one:
http://www.mokeaustralia.com/products/Windscreen_Frame-3-1.html
PostPosted: Fri Jun 14, 2013 6:49 pm
You can make the frame fit by extending the side uprights at the bottom.
the early frames stop about 3-4" shorter than the later ones that go right down to the top of the guard. try your old frame and you'll see the difference.
The later ones also have bolts on the side of the frame for the metal framed side screens, which also helped support the frame if you have a laminated screen.
PostPosted: Fri Jun 14, 2013 8:17 pm
Die Die Die!!
cheers for the link awd moke,
ill have to order myself one of them :)
PostPosted: Tue Jun 18, 2013 10:06 pm
Die Die Die!!
ok so ive accepted a quote for the moke to be painted, and it should all be done within 3 weeks :)
PostPosted: Wed Jun 19, 2013 7:00 am
3 weeks panel beater speak?
Could be another year yet! Hopefully you've found a decent one
PostPosted: Wed Jun 19, 2013 11:23 am
Yep, that could mean anything from 6- to 12-months!!
PostPosted: Wed Jun 19, 2013 11:27 am
Didn't you hear it'll only take three weeks of working...
...from when they start it :lol:
Users browsing this forum: No registered users and 27 guests
