It is currently Thu Jul 31, 2025 6:00 am
PostPosted: Thu Jun 13, 2013 5:08 pm
Hi
Currently out of action with a ruptured achilles tendon , so no driving for a while.
As i get chauffeured around i wonder about the apparent ease of modern day clutches.
eg My wife has the 1.5 litre Micra , good for 75kw/136 nm or 100HP in old the old scale.Clutch is so light it is almost pretend . If i did that HP in a mini i would need an orange or maybe Grey clutch with a considerable heft to it.
What is the difference , hydraulics sizes????? Cheers
PostPosted: Thu Jun 13, 2013 5:13 pm
Milatsmadmini
Take the mighty return spring off the slave cylinder and it'll be a shiteload easier to push :wink:
And yes it will self level/self return...
PostPosted: Thu Jun 13, 2013 5:23 pm
Pedal in the micra probably has two feet of throw on it.
PostPosted: Thu Jun 13, 2013 7:02 pm
micra's are cable clutch, my k11 micra is pretty light but ive heard a common issue is snapping the return spring in them so at a guess there not very strong springs
PostPosted: Fri Jun 14, 2013 10:49 pm
I recently had to do the throwout bearing and took the opportunity to renew the hoese, salve cylinder, arm, pins etc. Eg everything from the master cylinder through to the bearing.
Made a heck of a difference - not quite as light as driving my old laser but not too far off it.
Alec
PostPosted: Sat Jun 15, 2013 8:10 am
thanks all,
mattsmadmini , it is a mighty spring and i am getting old:)
Wally , harley i am sure the modern designs use better leverage too
1275ls this looks like a job to do when i change over the brake lines to wheels
thanks all
