It is currently Sun Jul 27, 2025 1:43 am
PostPosted: Sat Jun 15, 2013 4:01 pm
Hmm,
it seems one of my wheel studs seems to be about 1/4" shorter than the others now and i can't get a wheel nut on when the wheel is fitted? There doesn't seem to be anything protruding at the back as though it has been pushed back???
So how does a wheel stud get shorter? I don't recall having problems putting the wheels on b4??
Also I am trying to ID my brakes, I believe they are the 7.5 cooper discs but I am not certain. The part number on the disc is 21A1865 but I cannot find a reference to it anywhere? The calipers are Lockheed and the part number appears to be 10A21241 (though the letter is hard to read through the paint).
any thoughts?
cheers,
CJ
PostPosted: Sat Jun 15, 2013 5:20 pm
Get a photo.
If you reckon one stud is a quarter inch back from the others and you can't get a nut on, that means the other 3 only have a quarter inch engagement which isn't enough.
PostPosted: Sat Jun 15, 2013 6:12 pm
Harley wrote:
Get a photo.
Hmm will get a photo tomorrow. Looking at the various sites there seems to be 2 lengths for wheel studs. Am I better off getting the 1/2" longer ones? Currently I have 12x5 minilites on but I am thinking of going to 10x6's soon.
PostPosted: Sat Jun 15, 2013 6:43 pm
I am willing to be corrected BUT I think there are at least 3 different length studs?
Std Drum brake minis, front and rear
Disc brake hub
Cooper S rear Drum brake
I await the responses 8)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jun 15, 2013 9:57 pm
Pretty sure there is 2 sizes . Last time I was at Karcraft I got the longer ones to suit cooper discs.
PostPosted: Sun Jun 16, 2013 6:21 am
More like 7-8. I've worked on cars with 4 different on one hub.....
http://www.mini-hb.co.nz
PostPosted: Sun Jun 16, 2013 1:59 pm
ok so I have a few photos
The stud on the right is visibly shorter thant he others, I never noticed it before?
When I measure two of the studs I get the following:
Short one
All of the others
Now when the wheel is fitted the gap is pretty obvious
Since I am having issues with the wheels and looking a little closer, I don't even think the wheel nuts are the right type :? Shouldn't they have the straight section which goes thru the rim instead of just the flange like mine have? More like http://www.ebay.com.au/itm/CLASSIC-MINI-3-8-UNF-MAG-ALLOY-WHEEL-NUTS-SET-OF-16-plus-WASHERS-/111077508835?pt=AU_Car_Parts_Accessories&hash=item19dcbc46e3
PostPosted: Sun Jun 16, 2013 2:58 pm
No you have performance rims and the taper nut you are holding is the correct type. Looks like the stud is too short. You'll notice with the taper on the nut it sort of goes back through the wheel and will grab a bit of the stud but I think there should be more sticking through. On mine there is about 1/2" sticking though the wheel so it would engage about 5/8" or so. I'd have to measure it to give you an exact number.
Alec
PostPosted: Sun Jun 16, 2013 2:59 pm
And that short stud looks damaged. I'd ditch it for a new set once you get the length you need sorted.
Alec
PostPosted: Sun Jun 16, 2013 3:12 pm
hmm ok a new set it is, but how do you get the bloody things out?
PostPosted: Sun Jun 16, 2013 3:26 pm
BFH.
Best done with the rotor OFF the car, as the hammer blows don't help the wheel bearings.
I'd say someone has busted a stud and put a flat drum (shorter) stud in there.
PostPosted: Sun Jun 16, 2013 3:57 pm
BFH.
Hmm couldn't say, the history of the rotors is not known as i bought them second hand last year when I converted from Honda brakes.
I will try to get a new set for both sides and do them all at the same time. So are standard length ones on or should I get the 1/2" longer ones?
CJ
PostPosted: Sun Jun 16, 2013 4:40 pm
yeah looks like a std drum stud to me
disc studs are longer ones with a flat back/head
the drumystudss have a domed head/back
PostPosted: Sun Jun 16, 2013 6:10 pm
I measured my studs, with the wheel off, and they stick out about 23-24mm.
Soooo I would suggest your studs @20mm are too short :wink:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sun Jun 16, 2013 6:11 pm
Also , I reckon your wheel nuts are correct, just the studs are too short...
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: No registered users and 112 guests
