It is currently Wed Jul 23, 2025 12:12 pm
PostPosted: Sun Jun 16, 2013 1:18 am
I have a Mk1 Cooper S Dissy No 40819 and want to convert it to electronic ignition.
Ebay has 2 around the $50 - $60 mark.
One is called Stealth II With adaptive dwell
The other is called Accuspark.
Has anyone used these and what are your thoughts?
PostPosted: Sun Jun 16, 2013 1:57 am
Rover Cooper
You will get quite a few replies about this topic, it pops up on a regular basis, help and advice are on the wayB-) B-)
PostPosted: Sun Jun 16, 2013 10:42 am
I fitted the Accuspark to my 23D S dizzy, was easy to fit and ran great. No troubles with it whatsoever. Would suggest playing around with opening the spark plug gap a little.
Steve
PostPosted: Sun Jun 16, 2013 6:23 pm
I converted my MK1 S dissy way back using the Lumenition optronic kit. Has worked well ever since for many years, but now there a lot more players in the field and most are a lot cheaper.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Mon Jun 17, 2013 9:41 am
on the topic of electric ign upgrade's is this kit sold by MS worth it http://minisport.com.au/prod1594.htm $300
compared to an Accuspark kit on ebay thats only $200
http://www.ebay.com.au/itm/Classic-Mini ... 7f0&_uhb=1
PostPosted: Mon Jun 17, 2013 10:19 am
Im pretty sure convertable mini on here sells these as well .
Cheers Bill
PostPosted: Mon Jun 17, 2013 1:35 pm
I ended up fitting a Fireball XR700 after my local mini specialist recommended it and Dad happened to have one. Others do the job but he hasn't had any problems with these. There was a noticable difference when I fitted it, best thing I have done.
PostPosted: Mon Jun 17, 2013 1:37 pm
I had a Pertronix ignitor in my Mk1, it worked fine.
PostPosted: Mon Jun 17, 2013 7:00 pm
EVERYONE IS RECOMMENDING EVERYONE ELSE'S PRODUCT. ... HERE IS JUTS TO LET YOU NOW THAT I SELL ELECTRONIC IGNITION KITS TOO. MINE COST $60.00 POST FREE. I AM ONE WHO DOES MY BEST TO SUPPLY THE MINI COMMUNITY WITH ELECTRICAL PARTS AT THE BEST PRICE POSIBLE. I NEED YOUR SUPPORT OTHERWISE I WILL NO LONGER BE ABLE TO HELP. THANKS TO ALL THOSE WHO HAVE SUPPORTED MY BUSINESS IN THE PAST.
"Let us remove your "SHORTS"
PostPosted: Mon Jun 17, 2013 7:40 pm
My car has one of ^^^ Convertible's in it and it runs perfectly. It has been sat with ignition on but not running for ages while I tried to diagnose a fuel sender fault and never blew up the widget.
Don't ask me the brand. It was in the car when I bought it. I just found the receipt in the book the P.O. gave me.
My othe car has one of his alternators and that's perfect too.
M
PostPosted: Mon Jun 17, 2013 10:07 pm
I've got one of Tony's electronic dizzies in mine and she doesn't miss a beat now :)
'77 Leyland Mini Van
PostPosted: Tue Jun 18, 2013 8:24 am
The Mini King
I agree, it is not always the price that matters, With tony You get good advice and good quality, And Quality is a real issue to day, and that is because everyone is looking at price and the manufacturers, & suppliers of quality parts are closing their doors and then You will only be able to get low quality parts, People like tony are an asset the Mini community can ill afford to loose, So try and give him a go I Have never heard a bad word about the quality of the parts he sells
End Of rant
PostPosted: Tue Jun 18, 2013 8:37 am
Tony also does a great Bosch geared starter for big HP motors, it spins my 1360 like a top. Even when it's 2°C outside... :wink:
PostPosted: Tue Jun 18, 2013 10:39 am
Mine has one of Tony's kits in there's. Simple to install and you can ask him a question to clarify if you need, he tests every one and they don't break the bank.
1978 Leyland Clubman
PostPosted: Tue Jun 18, 2013 6:19 pm
To be honest one has to have bricks in the head to run points and condenser these days.
