It is currently Sun Jul 27, 2025 2:01 pm
PostPosted: Sun Jun 16, 2013 6:15 pm
ok so should I go for http://www.minisport.com.au/prod618.htm or http://www.minisport.com.au/prod2041.htm?
I am thinking the first ones?
PostPosted: Sun Jun 16, 2013 6:23 pm
Have also found these
ebay uk?
http://www.ebay.co.uk/itm/SET-OF-4-CLAS ... 416e171dbc
PostPosted: Sun Jun 16, 2013 6:31 pm
The Mini King
These are correct, the others from UK RLJ10001 are used with the stepped brake drum
PostPosted: Sun Jun 16, 2013 6:42 pm
Running Discs
These from minisplus
http://www.minis.com.au/minis/catalog/p ... cts_id=970
PostPosted: Sun Jun 16, 2013 9:49 pm
While I am replacing the studs i think I will refurb the calipers as well.
How often do the pistons need replacing? Since I will be ordering before I get to pull them apart are they an item that is a most likely to need replacing or are they a rarely ever need replacing item?
PostPosted: Sun Jun 16, 2013 11:00 pm
Original S caliper pistons were hard chrome plated, they don't wear really. This plating was fine when new however when they get old, corrosion can come through as pits.
Have a look when you remove them...
S/S replacements are common, but you can still get chromes ones I think.
