It is currently Mon Jul 21, 2025 6:17 pm
 Post subject: which Wheels to buy ?
PostPosted: Tue Jun 18, 2013 10:14 pm
Die Die Die!!
ok i need your opinion, im trying to decide which wheels to buy for my moke
im looking at the 15x7/16x7 range, (im under the impression that they will fit without mods and are of the right PCD)
im planning to paint my moke this colour -
option 1 15x7.5 - is the blue too much ? AUD$240
http://www.allwheels.com.au/product.php?productid=31213&cat=0&featured=Y
option 2 - 15x7.5 - [font=Verdana]AUD$240[/font]
[font=Verdana][size=78%]http://www.allwheels.com.au/product.php?productid=31211&cat=0&featured=Y[/size][/font]
option 3 - 15x7 - [color=rgb(201, 116, 119)][font=Garamond][/size][size=0.9em]£250[/size][/font][/color]
http://www.force-racing.co.uk/uploads/i ... 15-dsy.jpg
http://www.force-racing.co.uk/wheels-15/
Option 4 13x7
http://www.minispares-online.co.uk/?cat_id=202&sub_cat_id=208&prod_id=3246
option5 13x7
http://www.minispares-online.co.uk/?cat_id=202&sub_cat_id=208&prod_id=3265
option 6 13x7 - £78.55
http://www.midlandwheels.com/Shop/P-2834-7-x-13-JBW-Mamba-Black.html
PostPosted: Tue Jun 18, 2013 10:24 pm
Die Die Die!!
theres also these too
http://mach5wheels.co.uk/wheels/mach-5- ... stud#!/-1/
PostPosted: Tue Jun 18, 2013 10:47 pm
a 7" wheel (pretty much no matter the offset, because they will come very close to the trailing arm) is going to stick out a fair way on a Moke with standard guards.
Good luck.
PostPosted: Tue Jun 18, 2013 11:42 pm
Die Die Die!!
How did you overcome it willy ? We're your modified ?
PostPosted: Wed Jun 19, 2013 7:39 pm
Make sure the wheels are a 4 inch (101.4?) PCD and not a "make them fit" 100 PCD.
It may only be 1+a bit mm smaller but you'll be bending the studs and obviously that ain't good.
You might be able to get the wheels drilled to a 4 inch PCD :?
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Wed Jun 19, 2013 8:06 pm
I gave it a lot of thought and can't go past option 5
The chrome ones are too chrome, if that makes sense.
I couldn't blame you for going with option 1 or 3 either
PostPosted: Thu Jun 20, 2013 9:43 am
If you can afford them get the force racing wheels, mini lites are like a rse holes..
Be different, but not orange 4 spoke different
Potato
PostPosted: Thu Jun 20, 2013 9:47 am
Another vote for option 5
1965 Mk1 Cooper S Sprint/Hillclimb/Rally Car
2012 Land Rover Defender 90
PostPosted: Thu Jun 20, 2013 11:37 am
option 3
Carls wheels are Da-Bomb
PostPosted: Thu Jun 20, 2013 11:56 am
option 1
but I bet you will go for the ones you want, not which option gets the most votes :wink:
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Thu Jun 20, 2013 1:23 pm
wait till you have a drivable car....
PostPosted: Thu Jun 20, 2013 1:27 pm
Die Die Die!!
Well apparently 7.5" width isn't going to under the guards too well, might go for 15x7
PostPosted: Thu Jun 20, 2013 2:21 pm
Just widen the guards. Its just sheetmetal!
Carls wheels (force racing) are awesome. A++, would buy if had the money
1963 850 - laid up
Users browsing this forum: timmy201 and 72 guests
