It is currently Fri Jul 25, 2025 10:52 pm
PostPosted: Sun May 08, 2005 3:52 pm
I was just wondering if this is a mini related part as i recieved it with some bits and pieces when i bought my mini?
Also does anyone know if these are cooper s mags or are they aftermarket ones thanks.
PostPosted: Sun May 08, 2005 3:53 pm
Ok well i thought i would give it a shot, putting pics on here that is can someone tell me how to do it thanks
PostPosted: Sun May 08, 2005 4:03 pm
Putting pics on the forum:
you have the right idea. but for the first pic you must close the Img tag, when you do this you have to have them on the same line of text. (second pic not on same line)
all you have to do is highlight the link and press the Img button on the top, like you have previously done.
Pic 2:
[img]http://www.cardomain.com/memberpage/836015/3
[/img]
hope this helps
EDIT: it didnt work for me either, are you sure you copied the links correctly? i'm going to check the links out...
78 Leyland Mini - Prince
PostPosted: Sun May 08, 2005 4:09 pm
Thanks Dylan
Hope this works now. just want to know if this is a mini part and if these are cooper s mags
EDIT: ok it didnt work here is the web page the pics are on
http://www.cardomain.com/memberpage/836015/2
PostPosted: Sun May 08, 2005 4:16 pm
hehehe i just found the problem. the Img link has to be the actual picture. the above links just go to your site.
in regards to your questions.
1. no idea.
2. they look like Contessas, i have a set. i believe they are not Cooper S wheels
PostPosted: Sun May 08, 2005 4:19 pm
Ok thanks heaps for your help i think ill just leave it with the web pages.
PostPosted: Sun May 08, 2005 6:02 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i think it could be something like a halda trip meter they use on rally cars
makka
PostPosted: Sun May 08, 2005 6:05 pm
this it?|
PostPosted: Sun May 08, 2005 6:10 pm
minster wrote:
....Also does anyone know if these are cooper s mags or are they aftermarket ones thanks.
The Cooper S did not come with Mags. They came with steel wheels.
PostPosted: Sun May 08, 2005 6:13 pm
to aussie16 : nah thats not it but thanks for your help anyway
to min13k: oh ok then thanks
to Morris 1100: oh ok i should have realised that
Thanks for everyones help
 Post subject: Better foto needed
PostPosted: Sun May 08, 2005 6:22 pm
aussie16 wrote:
this it?|
ahhhh..if you can take the same shot in daylight without the flash we will be able to read the tally plate... :D
 Post subject: Sender??
PostPosted: Sun May 08, 2005 6:25 pm
makka
could be the SENDER for a Halda....
but it looks like a hydraulic or brake circuit item..
PostPosted: Sun May 08, 2005 6:49 pm
thanks to Aussie16 for putting the pics on for me, on this part it says
Veeder-root limited dundee scotland
registered users of trademark
Nos 201711 & b 514828
Form A/133846
Patented Great Britain No 581816
thats what it says on the plate its a little hard to read but that it thanks everyone
 Post subject: Hmmmm
PostPosted: Sun May 08, 2005 7:02 pm
Form A/133846
Well Veeder are certainly big in fuel/fluid distribution and monitoring systems....my guess is that it is either a fuel flow sensor or fuel control device....without much thought or further research :!:
PostPosted: Mon May 09, 2005 8:10 am
the mags look like ROH minilites which are an after market mag wheel.
I have a set up for sale if anyone is interested.
