It is currently Sat Jul 19, 2025 6:45 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: Fitting larger fuel tank
PostPosted: Sat Jun 29, 2013 9:11 am
I presume any mini can fit either a small tank or a large tank...
What will be required to bin my 5.5 gallon and install a 7.5 gallon?
1975 Clubman
1152cc, 40dcoe weber, RE83 cam, GRed head.
PostPosted: Sat Jun 29, 2013 9:59 am
1x Bin.
1x 5.5 gallon tank.
1x 7.5 gallon tank.
:wink:
I think they take a different strap? Can't remember off the top of my head.
So what's the last thing you remember...
I'm pretty sure you were..
WRONG ANSWER!!!
PostPosted: Sat Jun 29, 2013 10:06 am
The 7.5 uses the same strap as the5.5 but there is a 10 gallon one as well which uses a diagonal strap across the back of it to stop it moving about. I have one 10 gallon one here but no strap so can't instal it. Will have to make one eventually :D
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sat Jun 29, 2013 10:24 am
Hooroo
What model used this 10 gallon tank ?
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Sat Jun 29, 2013 10:27 am
Panthersteve wrote:
Hooroo
That's what I was thinking... :?
WRONG ANSWER!!!
PostPosted: Sat Jun 29, 2013 10:32 am
I was thinking the diagonal strap is required for the 7.5 gal?
1975 Clubman
raisto2 wrote:
1x Bin.
1x 5.5 gallon tank.
1x 7.5 gallon
Almost too easy
1975 Clubman
PostPosted: Sat Jun 29, 2013 10:39 am
sam_1100 wrote:
raisto2 wrote:
1x Bin.
1x 5.5 gallon tank.
1x 7.5 gallon
Almost too easy
couldn't resist. :lol:
WRONG ANSWER!!!
PostPosted: Sat Jun 29, 2013 10:55 am
The 7.5 gallon tank uses a diagonal strap - there is an extra bracket in the boot for these cars (UK)...
However the original 5.5 gallon strap still works with the 7.5...
So yep - take one out - put the other in....
PostPosted: Sat Jun 29, 2013 10:56 am
Never heard of three tank sizes, only ever known about the imperial 5 and 7.5 gal tanks.
A US 10 gal tank s pretty much the same as a UK 7.5 gal tank.
Are we sure there's no mix ups?
PostPosted: Sat Jun 29, 2013 11:02 am
10Gal US = 37.85ltr
*7.5Gal Imp = 34.09ltr
~3.75ltr Difference..
My guess is a mix up, or some rare aftermarket/ oddball euro thing.
*fixed.
WRONG ANSWER!!!
PostPosted: Sat Jun 29, 2013 11:26 am
You could fit a RH tank instead, either steel, or the aftermarket plastik fantastik one.
PostPosted: Sat Jun 29, 2013 12:50 pm
10Gal US = 37.85ltr
10Gal Imp = 34.09ltr
I am guessing you mean 7.5 Gal Imp = 34.09ltr.
Alec
PostPosted: Sat Jun 29, 2013 12:51 pm
10Gal US = 37.85ltr
SSSssssssshhhhh!!!! :oops:
WRONG ANSWER!!!
PostPosted: Sat Jun 29, 2013 1:18 pm
Got the two side by side and one is bigger than the other. Bought it at a swap meet in goulburn many moons ago and has a relief in the bottom to fit over the battery cover. It may have had a patch put in it but I am not stripping the paint to check. :D
Just bought a plastic RH tank on fleabay so will have to punch a hole in the other side to fit. Does anyone have a definitive way to make the template for drilling a hole?
Hooroo
Rob Forsyth
Miniot!!
