It is currently Sat Jul 19, 2025 10:46 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jun 29, 2013 1:28 pm
Thanks for the responses...
Sounds like ill have a new tank installed tomorrow afternoon after I visit a fellow Ausmini member.
1975 Clubman
1152cc, 40dcoe weber, RE83 cam, GRed head.
PostPosted: Sat Jun 29, 2013 1:44 pm
CPOCSM wrote:
Got the two side by side and one is bigger than the other. Bought it at a swap meet in goulburn many moons ago and has a relief in the bottom to fit over the battery cover. It may have had a patch put in it but I am not stripping the paint to check. :D
Just bought a plastic RH tank on fleabay so will have to punch a hole in the other side to fit. Does anyone have a definitive way to make the template for drilling a hole?
Hooroo
Taken from Minifinity,
Basically, you remove the left hand tank, draw a template of the hole and the edges of the panel onto a piece of paper, cut out the hole, and then flip it over and it mirrors the other side of the car...
So what's the last thing you remember...
I'm pretty sure you were..
WRONG ANSWER!!!
PostPosted: Sat Jun 29, 2013 1:57 pm
Hooroo
Yep, that method worked fine on mine.
PostPosted: Sat Jun 29, 2013 3:29 pm
If it has a relief to go over the battery cover wouldn't it be a right hand tank :?: :?: :?
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Sat Jun 29, 2013 5:21 pm
Why do you think I am buying a plastic one so I can have some of my boot space back? Got a 7.5 gal one on the left...there would be NO room if I put the 10 gal one in on the other side :D
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sat Jun 29, 2013 5:40 pm
Hooroo
don't want to sound like a skeptic, but do you have a pic of the 10gal tank? next to a 5.5 or 7.5 by chance? more out of curiosity than anything, not trying to prove a point or anything.
WRONG ANSWER!!!
PostPosted: Sat Jun 29, 2013 9:15 pm
For sure. Will have to dig it out of storage. And I have the LH out at the moment to do the hi lo stuff. Don't have a 5 gal one though so will have to use your imagination :D
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sat Jun 29, 2013 10:46 pm
Hooroo
First time in nearly 10 years of mini ownership that I've ever heard of a 10 gal tank so I'd be interested in a pic too.
Imagine, 10 gal plus 5.5 gal right hand side, 15.5 gal of fuel! 60 Liters! I'd be able to drive 600kms without refilling!
Lillee - 1969 Morris Mini K
PostPosted: Sun Jun 30, 2013 9:44 am
Well really deflated now as I retrieved the RH tank and it is a butchers job using a RH tank with a 3 inch insert strap around it. The fellow I bought it off cut the tank an inch off the flange and welded the strip in then welded the cut half back to the strip.
Thought I had something special.... :cry: and it leaks!! Water pissing out of the bottom of it(no wonder it was painted so very nicely!). It holds 10 gallons...just a pity it doesn't hold it for long.
I will crawl back under my rock now
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun Jun 30, 2013 10:17 am
just while where on fuel tanks with the design of the mini tank would that mean using a fuel cell would be legal? i know using 1 in a car with a standard under car tank isnt but ive never looked into it in a car with an exposed tank in the boot & ive seen cells that are 20gallon, would only need to fill up once a month lol
PostPosted: Sun Jun 30, 2013 10:45 am
What we want is one of the oddball "works" ones...
eg from the 1967 Targa Florio...
From : http://mk1-performance-conversions.co.uk/karstens_car.htm
(and from the previous post experience..... "Don't try this at home" :P )
:D
PostPosted: Sun Jun 30, 2013 12:05 pm
Hooroo
Well that blows! I'm sorry I asked you to look now..
Although, you could always try and fix it up, then you'd have a 'one off' 10 gal tank, not factory, but 10 gal none the less. :wink:
Alternatively, you could just turn it into some form of art ... maybe a letter box or the like?
WRONG ANSWER!!!
PostPosted: Sun Jun 30, 2013 1:15 pm
I am determined to fix it. Would be great for long trips but severely limits your boot space and makes getting the spare out a real pain in the butt! The dripping is coming from the recess underneath where the battery gap was made. Might have dropped it a few times in the four moves I have done since I bought it!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun Jun 30, 2013 9:19 pm
Fill with water, then cap it, invert & and weld that sucker up. :wink:
Users browsing this forum: Bing [Bot] and 103 guests
