It is currently Sat Aug 16, 2025 5:22 pm
 Post subject: Diff ratio's
PostPosted: Wed Jul 03, 2013 9:23 am
Anyone able to give a breakdown of rpm to km/h (eg rpm @ 110km/h) for the different diff ratios? I have tried searching the forum as I am sure it has been posted before, but I could only find a set for the P76 :(
cheers,
CJ
PostPosted: Wed Jul 03, 2013 9:37 am
My 3.647 diff & 165/70-10 A008s does 4,600rpm @ a GPS 110KMH.
PostPosted: Wed Jul 03, 2013 9:40 am
I have 1975 Mini fitted with a 1380cc, 104 Cam, HIF 44, 3.1:1 diff ratio and using A+ standard Box and 12" wheels and does 100Km/Hr and sits on 3200 rpm. Makes it a pleasure to drive and also helps with Fuel economy. I have calculated that it does approx 15.5 Km / Litre. or 6.5 Lt per 100 Km. And Speedo is accurate according to My GPS.
"Let us remove your "SHORTS"
PostPosted: Wed Jul 03, 2013 10:45 am
3.44 diff (stock S, clubman ratio), 10 inch wheels in 4th gear:
2400rpm = 60km/h
2700rpm = 70km/h
3100rpm = 80km/h
4100rpm = 110km/h
8000rpm = Jail
Approx, except the jail part, that is for certain.
PostPosted: Wed Jul 03, 2013 11:02 am
Try guessworks website, easy to use for any combo!
http://www.guess-works.com/Tech/ratio.htm
Cheers Shane
PostPosted: Wed Jul 03, 2013 11:09 am
Cheers Shane
Great site. Well I wasn't far off. I only remember it for my car only as I use tacho instead of speedo to gauge speed
PostPosted: Wed Jul 03, 2013 11:17 am
8000rpm = Jail
I suspect 8000rpm would be down a big hill? Conrod Straight? May be also followed by a few pistons trying to escape :shock:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Jul 03, 2013 11:19 am
Lillee's done 8000rpm every gear (cept 4th) at Western Sydney Dragway, several runs 8)
But yeah, not sure she could do it in 4th though :oops:
PostPosted: Wed Jul 03, 2013 4:32 pm
Excellent, thank you all for the replies. Looks like I need to add a new diff to the list of things I want/need to replace.
Since i will do almost all highway driving a 3.1 will probably be best if not a 2.95.
cheers,
CJ
PostPosted: Wed Jul 03, 2013 4:40 pm
A 2.95 will suck, it will be a dog off the line, even with a stock gearset inside.
[edit] I would go with a 3.1 or 3.2 for highway work.
Last edited by drmini in aust on Wed Jul 03, 2013 4:54 pm, edited 1 time in total.
PostPosted: Wed Jul 03, 2013 4:51 pm
I must admit my mini isn't anything special, pretty stock really 1275 twin 1-1/4 su's on 12" rims. I don't want to turn it into a real pig to drive but I would like to make it a nice cruiser (what I mainly do anyway).
cheers,
CJ
I have a 3:1 in my mini on 10" wheels and I love it, still good around town and on the highway it sits well under 4000. From memory 120km is around 4000.
My twinki engine will get eiter a 3:1 or a 3:2.
PostPosted: Wed Jul 03, 2013 5:05 pm
I used to run a 2.95 in a 1330, 731 cam, stock head, twin 1/4's & 10" rims. Nothing to right home about off the line but once your off the mark it was great. Cruised the highway at 3300 RPM at 100kph. It was a great combo. Good around town, but you need to use the gearstick a little more than usual.
With your 12" rims a 3.1 will sit at about 3350 RPM @ 100kph!
Cheers Shane
PostPosted: Wed Jul 03, 2013 5:09 pm
Cheers Shane
nice, but it won't have 12's as soon as i can afford 10's :lol: :lol:
PostPosted: Fri Jul 05, 2013 9:36 pm
I think you will find is pretty much:
3.76 = 14.6 mph/K revs
3.44 = 16.4
3.1 = 18.1
10" wheels (which of course are not all the same diameter) - but close enough.
Cheers, Ian
Users browsing this forum: No registered users and 218 guests
