It is currently Tue Aug 19, 2025 12:58 am
PostPosted: Tue Jul 09, 2013 3:41 pm
Hi All,
just a couple of quick questions before i put my doors back together...
How many of the little 'S' clips should be used to attach the chrome and rubber/rubber to the door, im guessing i need around 3 - 4 on both inside and out on both sides... so like 12 or 16 of the clips???
Are the standard door trim clips the way to go when attaching door cards? I was thinking it might be better to use 2 or maybe 4 stainless screws, or maybe just using the standard christmas tree clips?
and finally... are clip on mirrors on the A Pillar or Quarter Light any good (visibility wise)? or am i better off screwing a mirror into the door skin? (I have no mirrors or screw holes atm so can go with any option)
Thanks!
1975 Hairy Lime/White Clubby
PostPosted: Tue Jul 09, 2013 4:03 pm
The Mini King
Thorlek wrote:
Hi All,
The outer clip is 34G939 4 per door
the inner clip that holds the felt and the chrome strip is a totally different clip HYA1512, 4 Per door ( although some people use the 34G939 for this )
Use New clips and new sockets and it will work fine, Clip HYA1860 Socket 14A8094
I My opinion the mirrors that screwed to the door is a better option
Thanks!
PostPosted: Tue Jul 09, 2013 6:07 pm
You probably got those part numbers from the top of your head too didn't you John :)
If only I could remember stuff like this......
PostPosted: Tue Jul 09, 2013 6:27 pm
Not only that, he probably had a handful of each type of clip in his pocket. :shock:
PostPosted: Fri Jul 12, 2013 7:01 pm
does the chrome strip also get held on by this? do you just put this clip onto the door, put the rubber into the U on the inside... and the chrome over the bit thats on the door?
or do i need another clip for the chrome?
also, is there a gasket/rubber to put between the door panel and the outside handle?
thanks!
Users browsing this forum: No registered users and 346 guests
