It is currently Tue Aug 19, 2025 12:59 am
PostPosted: Fri Jul 12, 2013 10:06 am
Lillee wrote:
kiwiinwgtn wrote:
So Kev why did you change your mind and instal a booster
Maybe I'm getting old and soft...:mrgreen:
Won't be long until Chong has one too then? :lol:
PostPosted: Fri Jul 12, 2013 10:28 am
I found the unboosted brakes in my MG quite unnerving in the wet.
The feel between no brakes and lock-up was almost undetectable.
I put it down to the skinny tyres but I think a booster would also help a lot in those conditions.
PostPosted: Fri Jul 12, 2013 10:35 am
OK here's some pic links, sorry I've not worked out how to show thumbnails here yet..
http://www.flickr.com/photos/31275265@N05/9266582210/
http://www.flickr.com/photos/31275265@N05/9266581508/
http://www.flickr.com/photos/31275265@N05/9266580564/
http://www.flickr.com/photos/31275265@N05/9263804543/
PostPosted: Fri Jul 12, 2013 10:59 am
OK now you've PROVED you're going soft. Stereo? Pfft.... :lol:
Nice work. Have to say I've never felt the need for a booster, however I agree it may increase control. Space is the main issue for me (under bonnet is a PITA), so maybe under dash helps that.....was in two minds about the heater anyway!
http://www.mini-hb.co.nz
PostPosted: Fri Jul 12, 2013 11:18 am
Old age is a bugger when you need all the help you can get to push on the stop peddle - ah Kev?
David L
PostPosted: Fri Jul 12, 2013 11:53 am
Drove it to Karcraft and back this morning, it sure stops good now. Pedal is down a bit compared to with no servo, but no big deal.
When I adjusted the rear brakes up earlier I found my old drums were out of round, so I now have 2 new `shiny inside' Kc ones to fit. 8)
[edit] Pedal came up good with the 2 new Italian drums on.
Last edited by drmini in aust on Fri Jul 12, 2013 3:14 pm, edited 1 time in total.
PostPosted: Fri Jul 12, 2013 12:20 pm
Never really liked the idea of the brake booster being inside the car, well not a roady anyway. Instead I recessed the VH44 into the right hand engine bay wall slightly so I can do the clutch without removing the booster.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Fri Jul 12, 2013 12:26 pm
Got a pic of that? I have a vague memory an old car (Elf) of mine was like that too, damn memory........ :roll:
PostPosted: Fri Jul 12, 2013 12:27 pm
I've seen flexy lines used on the booster so it can be unbolted and flipped out of the way to access the clutch without needing to rebleed. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Jul 12, 2013 3:48 pm
Interesting fitment, I have heard a few people talk of mounting the booster under the front guard behind the headlight. Anyone seen this fit out or even better have any photos?
PostPosted: Fri Jul 12, 2013 3:53 pm
Used to be popular once way back when. The problem with that is the air filter on it gets clogged with road dust and slush... and has rocks thrown at it.
Mind you my Fiamm (ex Fiat) air horns are under there and working fine..
PostPosted: Fri Jul 12, 2013 5:12 pm
with my engine bay full of intercooler and pipe work there was no where to fit the booster so i mounted it in the RHF guard.
Got a pic somewhere...
could not find it but have take a quick one this morning with the wheel still on, not great but you get the idea.
100% Pure A Series Turbo
PostPosted: Fri Jul 12, 2013 5:36 pm
in a 71 model morris mini, not a solid parcel shelf so did not have to cut holes
PostPosted: Fri Jul 12, 2013 6:54 pm
Strange I cannot get your pics to work
PostPosted: Fri Jul 12, 2013 6:56 pm
crap...thought I could fix those...messed it up.... :lol:
Users browsing this forum: No registered users and 310 guests
