Hello all, I've put it off long enough but the time has come to rebuild the dissy on my 850 - the last service picked up that it was very worn and as a result the timing is scattered.
I'm just wondering what other 850 owners thoughts are on which way to go - at this stage I'm thinking of one of the following:
- Rebuild existing dissy and keep points ignition
- Rebuild existing dissy and fit a petronix or lumention electronic ignition kit
- Fit a complete new CSI electronic dissy, like this:
https://www.minispares.com/product/Clas ... o%20search
Has anyone on here had experience with the Minispares CSI electronic dissys? To have my distributor rebuilt will be around the $150 mark, for not much more I could just get the CSI kit and I wouldn't have to worry about trying to fit an aldon/lumention/petronix type kit. But for a standard 850 I'm not sure if this is overkill and if I would even notice the difference vs a rebuilt standard distributor - although not having to adjust points is another plus. As the car is on historic rego I've been reluctant to go down the electronic ignition path but the CSI solution suggests that you wouldn't be able to tell the difference unless you took the cap off.
Any thoughts/advice would be much appreciated!
