yep,,, there we have it ,,, gears not aligneded properbly
sorry but i can`t help typimngb funndy whenm things arented aligneded properbly
so,,, to remedy this problem,,, i`m going to guess you have no shims under the crank-gear yeah???,,, so,,, if that`s the case then get the cam gear off & have the abuttment-shelf & the thrust shoulder machined (in a lathe will do, but make sure you clock it true before machining it) enough so that the cam gear aligns with the crank gear.
most mini engines rely on the shims under the crank gear to align the crank gear to the cam gear
but what we do is machine the cam gear till it sitts square/straight... inline with the crank gear
2x skims,,, one from the most inner edge of the gear ,,,to align the gear with the crank gear,,, then skim some off the next shoulder in to allow for the cam thrust clearance
got it?
this way you will have no more dramas shredding slingers & you`ll even have a tiny weeny bit more power because you are not trying to pull shafts sideways into thrusts.
edit--> oh sorry,,, i may need to explain something here
std issue minis , with the shims under the crank gear to align the gears,,, is fine & dandy in a perfect world,,, but we are not all living in a perfect world now are we??? just like the balancing an engine thread of a little while ago--> not everything is how it was from the factory & even if it was , that was 30 or 40 or 50 years ago & no one knows who`s stuffed with it since then,,, or how many times it`s been stuffed with the wrong way r, right??? so,,, they (the shims) often they give trouble,,, especially if the crank has been hardened with the shims still sitting on the crank ,,, they then become very brittle & break & fall out & get all munched up in the gears/chain/cover,,, & then your front pulley comes loose & starts hitting the cooling fan while you`re driving along etc etc etc
so,,, to help avoid all that ,,, instead of shimming up the crank gear,,, we find it best to skim down the cam gear to align things yeah? -->
But don`t forget you need to skim things so there`s the right clearance for the cam thrust washer yeah???
anyways,,, that`s enough for the day,,, typing fingers going numb (again)
