It is currently Tue Aug 19, 2025 6:20 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jul 29, 2013 8:59 am
Doc
with bathtubed heads is the extra time(advance)needed to ignite the greater volume (especially at idle)
if yes, would extra dished pistons also benefit? (eg 10 -18cm)(turbo league)
from more advance at idle?
and finally if yes
interesting dilemma for turbos who need to dial back advance once going.... sensibly a case for MJ etc
PostPosted: Mon Jul 29, 2013 9:06 am
FNQ wrote:
Doc
and finally if yes
It is not the volume, it is the chamber shape. My 1360 is running 11.0:1 C/R now. Pistons are stock 9.75 Hypatecs, the head has had a lot off it.
http://www.flickr.com/photos/31275265@N05/9389133396/
With a bathtubbed head there is little or no squish area left. So the flame propagation from the spark plug is slower (which I read somewhere).
In comparison, the stock 1275 chamber shape is very good in this respect.
PostPosted: Mon Jul 29, 2013 6:11 pm
What about these? It says it has 16 programmed advanced curves. Otherwise I might have to go searching for a pulsar dizzy. What's the megajolt one
If its yours, customize it !
PostPosted: Mon Jul 29, 2013 6:32 pm
As the Doc said it's the shape of the chamber is the reason for more advance.
The flat section on 'normal' head is call squish or quench (depending on whether you're English or American. It was first understood by an Englishman) and this is what allows for late or retarded timing. It allows the engine to run smoother with less heat and stress.
PostPosted: Mon Jul 29, 2013 7:08 pm
The 123 dizzy was one of the first programmeable ones for a Mini but there are others now that are more friendly.
Mick (or somebody else) put a link up here recently, but the search function is fubar'd and I cbf looking for it by scrolling each page.... :lol:
PostPosted: Mon Jul 29, 2013 7:13 pm
hi 1380k
the megajolt is a distributor-less system.- infinitely programmable curves based on crank timing. ( see how tos for lots more info)
A number of programmable electronic distributors have a set number of maps (curves) you pick the one the best suits ( CSI, 123, Amethyst etc)
Single curve (typical) distributors are mapped for the masses , so tend to be conservative, however get one mapped for your spec by Performance, etc and it is customised exactly for your needs.
Horses for courses
Mg and doc , thanks for the info -
PostPosted: Mon Jul 29, 2013 7:47 pm
Posted: Mon Jul 29, 2013 6:11 pm Post subject:
Dr mini has done well to realise what I'm talking about. Whoops :oops:
The 123 dizzy is appealing to me ATM. Just for ease of purchasing and installing. That is assuming it has an advance curve suitable.
PostPosted: Mon Jul 29, 2013 9:55 pm
Did a bit of research and think I might just bite the bullet and get a 123 distributor. Even if later down the track I go megajolt or something ill chuck the 123 in one of my other minis :wink: I'm sure ill have more than one mini to muck around with.
Users browsing this forum: Majestic-12 [Bot] and 89 guests
