It is currently Thu Aug 14, 2025 3:32 am
 Post subject: Colourtune
PostPosted: Wed Jul 31, 2013 9:54 am
has anyone used the Gunson colourtune system to tune their cars?
http://www.gunson.co.uk/item.aspx?cat=673&item=1822
Is it worthwhile having or would it be a dust collector?
I guess that some kind of carb balancing tool too (rather than listening
through a tube)
thoughts anyone
PostPosted: Wed Jul 31, 2013 10:04 am
While we're here - can anyone recommend a decent carb balancing tool?
PostPosted: Wed Jul 31, 2013 10:11 am
I have a pair of the colortunes, they're a great tool. Trick is however that if you have a significantly modified engine with a large cam, large head, large carbs, whatever, the colortune will not be able to give you a reading that is valid across the tuning range.
ie. What appears to be tuned at idle, will not be tuned under load. So they work for a relatively stock engine. I love the tool anyway. I have a pair I use, either one for inner and one for outer, or because I am tuning twin carbs, and need one on both ends of the engine.
WRT the carb balancing tool, I have a colortune one here, but frankly have gone back to the length of heater hose to do it. The colortune cone type proves problematic when trying to fit over stock SU carb horns.
Hey Paul
I've used one but it always seems to be a bit off when finished and I adjust it by ear at the end. You can borrow it and try it out if you want.
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Wed Jul 31, 2013 10:31 am
I did the same.... though I found that the nice piece of white hose that came with the gunsons carbalancer felt very nice against the ear
PostPosted: Wed Jul 31, 2013 4:34 pm
For twin SUs i use a unisyn carb sync tool
http://store.edelbrock.com/4025uni-synafor1and2barrelcarbs.aspx
as an example only - can't remember where i got mine
PostPosted: Wed Jul 31, 2013 7:17 pm
Yeah,
Gunson carbalancer was a pain with the SUs. Had to cut a funnel and tape it onto the assembly to get a seal....also as the tube came out as was loose, lost the ball that shows the level of suction......got one out of my windmeter which is the same system and now it all works great.......
Yeah, get a Uni-syn!
Cooper S Mk2
Cooper S Mk1
PostPosted: Wed Jul 31, 2013 7:20 pm
I got a set off ear protection muffs drilled a hole in each one and stuck a pipe in each going to a tee then a pipe from the tee to stick in the carby, the muffs block out the engine noise. A bit like a stethoscope for your car, it is great
PostPosted: Wed Jul 31, 2013 7:21 pm
Ha ha! Brilliant idea, but photos please! 8)
PostPosted: Wed Jul 31, 2013 7:33 pm
I have a real car stethoscope, Gafmo bought it on line and gave it to me!
Works great, for tracing engine noises or twin carb tuning. :P
PostPosted: Wed Jul 31, 2013 7:36 pm
How do you find it? Does it have a clear advantage over listening through a tube?
PostPosted: Wed Jul 31, 2013 7:48 pm
PostPosted: Wed Jul 31, 2013 7:49 pm
You like ???
PostPosted: Wed Jul 31, 2013 7:50 pm
:D Very much!
I was having problems visualizing the setup, but now I see its all about the pertness of the breasts.
She looks moody, can she hold the tools while you work?
:lol:
PostPosted: Wed Jul 31, 2013 10:18 pm
Looks like the old fashion earphones planes had! Looks like an old fashioned air hostess too!
Cooper S Mk2
Cooper S Mk1
Users browsing this forum: Bing [Bot] and 263 guests
