Mick wrote:
I have a pair of the colortunes, they're a great tool. Trick is however that if you have a significantly modified engine with a large cam, large head, large carbs, whatever, the colortune will not be able to give you a reading that is valid across the tuning range.
ie. What appears to be tuned at idle, will not be tuned under load. So they work for a relatively stock engine.
This doesn't quite stack up for me. If you are getting the correct flame colour throughout the rev range for standard engine, and not for a modified engine, that's because the modified engine has not had it's fueling set up correctly. Either needle is wrong, or spring, or something else. It's not the colortune giving a bung reading. Afterall it's not a 'reading', it's simply letting you see the flame front.
Now, getting a correct colour through the rev range IS a bit tricky with colortune, as if you just sit there revving the tits off it in the driveway you are getting high revs with no load, which is not what you'll get on the road. But it's not a modified versus standard tune thing. Funky article out there somewhere from Vizard (I think) about using a colortune as a rolling road dyno: basically jack the car up, and drive with your foot on the brakes to simulate real driving
