It is currently Tue Aug 05, 2025 6:08 pm
PostPosted: Sun Aug 04, 2013 1:42 pm
I'm cutting my guards to suit 13x7 wheels and sportspacks, the guards are trimmed right back to the arches and the wheels still hit before they reach full lock.
Do most people with the big wheels put stoppers in somewhere to limit the steering angle?
PostPosted: Sun Aug 04, 2013 3:09 pm
there were some you would fit onto the rack shaft to butt between the knuckle lock-ring & the housing on full lock years ago,,, havn`t seen em for a while tho.
PostPosted: Sun Aug 04, 2013 4:02 pm
a sports pack steering rack
PostPosted: Sun Aug 04, 2013 4:28 pm
Try kad in uk
PostPosted: Sun Aug 04, 2013 4:41 pm
Minisport SA have the KAD ones.
I'll order them tomorrow.
Thanks guys!
PostPosted: Sun Aug 04, 2013 7:42 pm
Where do your wheels touch?
I have a standard Aussie rack and my 13x7s don't touch :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Aug 04, 2013 8:16 pm
When turning, they rub about 3 inches above the bumper lip.
Not a little bit either - the guard contacts with about 15mm of tyre tread to go.
PostPosted: Sun Aug 04, 2013 9:15 pm
Standard Aussie rack has less lock than the UK and aftermarket racks.
PostPosted: Sun Aug 04, 2013 9:19 pm
When you trimmed the guards, I assumed it was the front?
I trimmed my guards to line up with the body kit flares.
I have a magazine article with diagrams on how to trim for 13" wheels which I will post up if I get a chance tomorrow.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sun Aug 04, 2013 9:29 pm
Mine line up with the inside of the flares too.
I might be able to shift the flares forward a bit but not much - they kind of lines themselves up between the bumper, side lip and the indicator on the guard.
I'll probably trim a little more steel out, and carefully trim the fibreglass inside the flare, and reinforce where I can.
I'll put a rack limiter in there too - after all - how often do you need to turn that much anyway?
:lol:
PostPosted: Mon Aug 05, 2013 2:51 pm
it all depends on how low you have the car set
i have cut a good inch or two through the guard and the A panel and i still cant get anywhere near full lock , it also depends on the arches themselves mine are very old ( like 2002) and they were very hard to fit and match to the guard ... i need to go back and cut again
wheel alignment plays a big part to , lots of camber and caster makes it worse
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Mon Aug 05, 2013 2:58 pm
Yep, that all sounds like mine.
Been flicking through some UK build threads and to get full lock on a 13x7 means a big amount of guard has to go - more than I can manage with the arches I have.
Users browsing this forum: Flying Brick and 88 guests
