It is currently Mon Aug 18, 2025 4:38 am
 Post subject: What Mondeo to raid?
PostPosted: Wed Sep 11, 2013 7:45 pm
What year or model Ford Mondeo has the useful bits us mini guys want for efi/elc ignition set up?
 Post subject: Re: What Mondeo to raid?
PostPosted: Wed Sep 11, 2013 10:20 pm
first shape, automatic
PostPosted: Thu Sep 12, 2013 6:34 pm
What parts should I get and what are the worth $$$?
From what I can remember I need is the EDIS module and the coil packs + the connecting wires. Is that all I need from the Mondeo? (anyone have any pics of what we need?).
PostPosted: Thu Sep 12, 2013 7:02 pm
You can find pics/ info on here http://www.autosportlabs.net/Megajolt_Lite_Jr.
The only other thing you could grab would be the crank angle sensor.
PostPosted: Thu Sep 12, 2013 8:29 pm
You will need to find an early to mid 90's auto.
The edis unit is on the fire wall, behind the engine and to the LHS.
You will also need the coil pack and crank sensor. The crank sensor is at the front of the engine, down around the starter motor I think.
The better way to go is to use the Modeo edis unit, then use the crank sensor from an EL or early AU Falcon (Much easier to get and a better shape to mount), and use a coil pack from a Hyundai Excel (smaller better shape and use normal plug leads, not the clip on ford ones).
Check out Simon's Megajolt Ignition in How To for pics and wiring diagrams.
Good luck.
1970 MK II Cooper 'S' Supercharged 1310 with Megajolt.
1970 MK II Cooper 'S' Original resto project (SOLD)
1962 850 Original. (Under restoration)
1973 Leyland S (My first car. Now rebuilt, so my kids can learn how to drive a real car).
VMCI # 215.
PostPosted: Sun Sep 22, 2013 8:02 pm
Edis is superseded now, Mega jolt and squirt can both drive coils directly so no need for edis.
Users browsing this forum: No registered users and 138 guests
