It is currently Mon Aug 18, 2025 2:55 am
PostPosted: Sun Sep 01, 2013 8:32 pm
Greetings all.
The original Carbies have a little bulb and metal capillary tube which went to the distributor vacuum advance thingo. As it was bent all over the place, I can't work out it's proper "Path". It has a saddle clip which (by size) must sit under the water tap nut. Can anyone post a side on picture of how this is positioned please?
Also, can these be bought new anywhere?
I like the original look.
Alex
PostPosted: Thu Sep 12, 2013 1:47 pm
Hi Alex
If it's the one I'm thinking of, it goes from the carby to the distributore and the saddle clip is bolted onto the thermostat cover.
I don't have a photo of the position of the pipe but here's a link to where you can buy one.
http://www.ebay.com.au/itm/Advance-Reta ... 821wt_1161
Dave
"64 Smooth Roof Van (Colin)
PostPosted: Thu Sep 12, 2013 2:18 pm
I agree with waldo, that's where my 850 had it.
PostPosted: Thu Sep 12, 2013 10:38 pm
Thanks Dave & Doc.
The links the one I need. This one is too bent to recover. I can go plastic, but the metal does look better.
Alex.
Users browsing this forum: No registered users and 309 guests
