It is currently Fri Jul 18, 2025 9:25 pm
PostPosted: Tue Sep 24, 2013 10:51 am
I've found this type at minispares and a few other places, but can't seem to find the original cage type switch (not the screw in type)
Does anyone know of anywhere that has stock of the old type, or another model car that uses a similar one that would fit?
PostPosted: Tue Sep 24, 2013 4:05 pm
You are looking for Linread brand switches. They are no longer made but come up on eBay quite often, especially eBay UK. Expect to pay good money for one given what it is because they are fairly rare. The Mini one has a bent shaft (see the one on the left in the photo with this eBay sale).
http://www.ebay.co.uk/itm/ORIGINAL-LINR ... 41768c8b02
Another version has a straight shaft but this could be bent to suit.
http://www.ebay.co.uk/itm/Jaguar-E-Type ... 35cc0e78ff
If you are not wanting originality there are other options - see this thread - viewtopic.php?p=496915
Otherwise try all the local Mini parts suppliers for second-hand ones - viewtopic.php?f=25&t=10543
PostPosted: Tue Sep 24, 2013 6:37 pm
Shot Matty Read a PM , (TheMiniMan ) , i seem to recall a discussion about these a fair while ago ,
and i think Matt said that he had some , Don't quote me though .
PostPosted: Tue Sep 24, 2013 11:40 pm
Cheers Winabbey, tonnes of good info there! Thanks Goodie I'll check with Matt :)
PostPosted: Wed Sep 25, 2013 5:19 am
I have switches similar to the ones in picture above (plenty in stock). They fit great on Mini. I have used them on my own cars too. Orders welcome. Email me.
"Let us remove your "SHORTS"
PostPosted: Wed Sep 25, 2013 8:20 pm
Cheers Tony if i have no luck sourcing the original ones i'll give you a ring and get some of the clubby style ones.
PostPosted: Wed Sep 25, 2013 9:51 pm
yeah i think i have a few genuine originals left in stock,
but i`ll be away at Morgan Park raceway for the IP Nationals
till next week sorry.
PostPosted: Thu Sep 26, 2013 7:49 am
Thanks Matt I don't need them this very second, will send you a pm :-)
PostPosted: Thu Sep 26, 2013 12:08 pm
The Miniking (John Schmidt) was selling the door switches from another Leyland. They were new old stock and nearly identical, however the wire terminals did not turn 90 degrees like a mini. You can't bend them 90 degrees, so don't even try or they will snap.....
I fitted them to my 69, and didn't have any fouling issues, but they don't suit all minis as the hole in the door frame moves a little further up I believe on some cars causing the switch to foul with the internal a panel. I am usure from where I am to check if the early cars switches are further up or down the door frame sorry.
Might be worth a shot.
Users browsing this forum: No registered users and 114 guests
