It is currently Fri Jul 18, 2025 9:24 pm
PostPosted: Mon Sep 23, 2013 11:13 pm
As the title says; the engine is coming out tomorrow as it's leaking oil from both ends. Badly.
While I have it out, the correct speedo drive will be installed and I'll probably have a look at the slack gearstick linkages. I would also like to fix up the rear breather to the carbs but the one I have is dead. The original will have a hose attached and vented to the ground a la 1962.
Is there anything else that I should be doing while the lump is out? It's too good an opportunity to waste.
Thanks
Behold! The mighty 850!
PostPosted: Tue Sep 24, 2013 7:27 pm
how's the steering rack? much easier with the motor out
PostPosted: Tue Sep 24, 2013 9:49 pm
bypass hose :lol:
PostPosted: Tue Sep 24, 2013 9:57 pm
Coming out the top or bottom?
If its coming out the bottom then get the top towers of the subframe welded up.
Simplify and add lightness
PostPosted: Tue Sep 24, 2013 10:01 pm
How was the clutch ?
(and if having to fix main seal oil leak - my be worth replacing anyhow while it's all apart...)
PostPosted: Tue Sep 24, 2013 11:12 pm
Well, that little lot should keep me busy over the long weekend.
Thanks all.
