It is currently Mon Aug 18, 2025 8:48 pm
PostPosted: Thu Sep 26, 2013 11:59 am
Hi all,
Just wondering what's involved with converting from auto to manual. Is it simple or so different that it is not worth it? I would be on an 88 Rover mini
PostPosted: Thu Sep 26, 2013 12:16 pm
Online
Mechanically:
If you want to fit a manual engine + gearbox you will either need a manual Rover subframe , or else modify the one you have to take the manual gearbox mounts (your auto subby is wider than a manual one).
If you are referring to converting the existing auto motor (different oilways) to work on a manual gearbox, see my sticky thread at top of this forum.
[edit] Topic has disappeared, I will find out where it went... :shock:
PostPosted: Thu Sep 26, 2013 12:25 pm
Thanks for the reply. Yeah was looking at possibly purchasing an auto and wondered the implications of swapping it over to a manual. I'm probably better of looking for a manual
PostPosted: Thu Sep 26, 2013 1:51 pm
Online
Here's that auto block to manual thread, apparently all the sticky threads came loose when transferred to the new forum and slid down the listing..
viewtopic.php?f=5&t=1461
Users browsing this forum: No registered users and 142 guests
