It is currently Tue Jul 22, 2025 12:11 am
 Post subject: earth wire in boot
PostPosted: Thu Sep 26, 2013 12:40 pm
Where should the earth wire in the boot connect?
The one in the loom near the pasenger tail lights
To the petrol tank strap? Or to one of the boot lid hinge bolts?
Thanks
1975 Hairy Lime/White Clubby
 Post subject: Re: earth wire in boot
PostPosted: Thu Sep 26, 2013 9:27 pm
Don't know about Oz cars .. but the rear loom on UK cars (including the fuel pump!) earths through the interior light (just above the pass side B pillar)
Cheers, Ian
PostPosted: Thu Sep 26, 2013 9:51 pm
Mines on the petrol tank strap.
PostPosted: Thu Sep 26, 2013 10:07 pm
Cheers Phil,
thats what i did with mine, but wasn't sure if it was correct.
it seemed too big to connect to a bonnet hinge bolt.
Thanks
PostPosted: Thu Sep 26, 2013 10:11 pm
No worries. Now looking at my own photo I'm wondering what the brown wire is heading off to the left???
Sent from my iPhone using Tapatalk - now Free
PostPosted: Thu Sep 26, 2013 10:39 pm
Either the fuel pump or the fuel tank I think.
PostPosted: Fri Sep 27, 2013 9:43 am
I recently found out that my brake lights weren't working - the cause was a poor earth for the brake lights with the wire as shown in the photo (attached to the tank strap) - the solution was to give the wire a bit of a wiggle and all good now. I'll remember that for next time.
PostPosted: Fri Sep 27, 2013 9:50 am
Its very common for that to happen. Last time I made a loom I wired all the earthing points together, so that if one developed a bad connection another earth somewhere else would still do the job. It makes it more reliable. They probably saved $2 worth of black wire by using lots of seperate short earth wires, rather than wiring them all together.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Sep 27, 2013 11:08 am
Confirming my MK II Cooper S earth point is the same as in Phill's photo - on the tank strap bolt.
PostPosted: Fri Sep 27, 2013 6:56 pm
Yes tank strap bolt
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Sep 27, 2013 7:36 pm
Cheers all. Thanks for the responses
Users browsing this forum: Majestic-12 [Bot] and 71 guests
