It is currently Thu Jul 17, 2025 4:22 am
 Post subject: Redline 3005 - new?
PostPosted: Fri Sep 13, 2013 11:19 am
Hey guys,
Speaking to a redline distributor, says they have brought out a new version of the 3005 with different angled ports for better flow. Has anyone heard of this?
Either way I'll be purchasing it with a 45 mm weber for my 1380!!!
77 Clubman
1100, was daily driver
waiting to drop 1380 in!!
 Post subject: Re: Redline 3005 - new?
PostPosted: Fri Sep 13, 2013 1:23 pm
I've not used the new one, just check that it takes a 45. The old ones needed porting, their top flange was only 42mm bore.
I'd get it flow tested before fitting to see how much better it is.
The originals only flowed ~137cfm, but after 9hrs porting mine flowed 197.
PostPosted: Mon Sep 16, 2013 10:50 pm
I have one on the way - can post photos when it gets here if you like.
PostPosted: Sun Sep 29, 2013 7:50 pm
Hi folks - i recently purchased a Mangoletsi 'competition' manifold and linkage kit from the UK for my 45. Price was similar or less than the Redline/Warenford offering, and the quality of the linkage in particular is very good. The manifold is progressively ported from a full 45mm down to the large manifold gasket port size, and is precision drilled for a very tight fit on the studs. It will fit a round-nose if you carefully cut the bulkhead, and fold (or bash) the lower lip down, and I run 28mm Specialist Components ram tubes inside an oval K&N with a Malpassi fuel reg and facet redtop pump. Don't have flow figures, but am getting good torque from a 1380 with big port head and STR930 cam, exiting through Brownrigg headers into a 2 inch Maniflow twin box, and Swiftune CSI dizzy. It goes! or at least it did until the belt drive shed a few teeth and the valves had a word with the pistons. My own stupid fault - the Pirelli belt (Triger setup) was fitted in 1985! I reckon nearly thirty years of service is pretty good - i was going to rebuild the head anyway - but the stupid part is not replacing the belt with the new kevlar jobby i bought two years ago...still in the box. Anyway - some pics must be worth several thousand words.
/Users/peter/Desktop/IMG_0802.jpg
/Users/peter/Desktop/IMG_0803.jpg
/Users/peter/Desktop/IMG_0804.jpg
/Users/peter/Desktop/IMG_0805.jpg
/Users/peter/Desktop/IMG_0806.jpg
/Users/peter/Desktop/IMG_0807.jpg
Min - 1970 MkII S, 119hp Dave Anton 1380, SH Engineering belt drive, 1.5 rollers, 123Tune ignition, 48 DCO SP Weber, HP Headers, MSD, Maniflow ex. Swiftune SC/CR 3.7 + ATB, all KAD front, antiroll bars and gas shocks, 6 inch Minilites with Dunlop Sports
PostPosted: Sun Sep 29, 2013 7:53 pm
that didn't work - can i post pics as attachments or do i need to link them? pardon my ignorance please...
PostPosted: Sun Sep 29, 2013 8:28 pm
i think this should work..
http://s884.photobucket.com/user/cranky ... mangoletsi
PostPosted: Mon Sep 30, 2013 11:10 am
while i think of it - i replaced the manifold studs with bolts into the head. makes it much easier to remove the intake and exhaust - lifts straight up, and the brownrigg headers can be removed without taking the whole engine out (live and learn - took me 20 years to figure that one out). i have also bodgied up a pcv system with catch tank for the weber manifold distributing to both runners and with brake booster too - no more smelly engine! will put some pics up soon. cheers
ps 'min' (very original) is a 1970 mkII S, with various, mostly period appropriate mods. i have had her since 1981 and did a bare metal rebuild in '85. bit shabby now (so am i) but i still love her.
