It is currently Sat Jul 19, 2025 12:10 am
PostPosted: Wed Oct 23, 2013 1:51 pm
Hey team , thought I'd run this past here and see what local guys are running on their minis for both daily and track/hillclimb/etc
What do you lot run or recommend for shocks?
What about rubber cones- oem , red or yellow dot ?
Interested to see what setups are here on Aussie roads cheers
PostPosted: Wed Oct 23, 2013 1:52 pm
PS I will be running original hi lows and will mostly have the car alittle lower than standard
PostPosted: Wed Oct 23, 2013 11:40 pm
Hi there,
Im running the red dots, and they are a bit stiffer than the original cones, however in using them for over 3 months i have found them satisfactory.
In any case i did try out the coilovers and have to say didnt enjoy the ride one bit, too stiff and not enought wieght in the back causing it to bounce around.
PostPosted: Thu Oct 24, 2013 7:08 am
Thanks for the reply
Yeah looking at red dots, what shocks do you run? Lowered at all?
I haven't considered proper coil over suspension at all, the geometry just doesn't look right in place of the shocks ! Plus I've heard its bouncy and requires much more setting up
Users browsing this forum: No registered users and 70 guests
