It is currently Fri Jul 18, 2025 9:57 am
PostPosted: Thu Oct 24, 2013 1:49 pm
Guys,
Thought i would show you this dash i recently brought, something a little different, using the standard Rover clocks centrally located! Looks good and means no chopping of wires etc...
From this.....
To this.....
PostPosted: Thu Oct 24, 2013 2:30 pm
Fair difference, looks like two completely different cars! :lol:
PostPosted: Thu Oct 24, 2013 5:06 pm
Looks fantastic. So you ditched your aircon?
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Thu Oct 24, 2013 5:10 pm
Say it isnt so .......... those bloody hot summers we get , i would have loved my clubby to have air con.
Do they sap too much power from the motor ?
PostPosted: Thu Oct 24, 2013 5:35 pm
I do like. 8)
PostPosted: Thu Oct 24, 2013 6:09 pm
looks good. how do you find having the speedo so far away? i guess its for a LHD mini?
PostPosted: Thu Oct 24, 2013 7:37 pm
In reality its not much further away than a centre Speedo although a little smaller..... Designed as a centre set up for a Rover gauge cluster!
A/c has gone.... Misses isn't an A/c person
PostPosted: Thu Oct 24, 2013 8:31 pm
So is the a/c setup forsale
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Thu Oct 24, 2013 9:47 pm
Hey Blunder.. Looks great.. Definite improvement IMO! Where did you source the air vents from? Did they come with the dash or are they retrofitted off something else?
Sent from my iPad using Tapatalk - now Free
PostPosted: Fri Oct 25, 2013 10:14 pm
That type of dashboard comes with the rover style vent holes already cut in it so he would just use his existing vents from the old dash
- '74 Clubman Ute project
PostPosted: Fri Oct 25, 2013 10:23 pm
Need a steering column drop bracket to get the steering column lower. It looks like that glove box in front of the column could be a bit tight to get open
The dash is real different. Im not a fan but you dont see one like it very often
