It is currently Tue Jul 22, 2025 7:40 pm
 Post subject: Ball joint hassles
PostPosted: Tue Oct 29, 2013 3:56 pm
OK spent 5 hours swapping shims and playing with the ball joints.
Cant get them just right - see the diagram - looking down on the pin I can get it too loose to the outside and too tight to the inside with it just right on the sides. I have rotated the seat through 90* steps but makes no difference - rotating the pin makes a little difference but not 180* so it makes me think the recess for the pin seat is out of square. The bottom pin was similar but once the spring is in it evens up nicely.
David L
 Post subject: Re: Ball joint hassles
PostPosted: Tue Oct 29, 2013 5:42 pm
Did you "lap the pin to the cup"?
It seems to be the go these days when replacing your ball joints.
Chers Shane
PostPosted: Tue Oct 29, 2013 5:50 pm
Well and truly lapped
David L
PostPosted: Tue Oct 29, 2013 6:07 pm
Poorly made stuff these days, I fitted 2 NOS Australian made ones recently that I've had for years, and they were perfect. No need to lap.
Nope sorry, I don't have any left...
PostPosted: Tue Oct 29, 2013 6:10 pm
I take it when the pin & cup are off they feel perfect together due to your lapping!
Does the base of the pin foul on any part of the housing as you rotate it around?
Cheers Shane
PostPosted: Tue Oct 29, 2013 6:40 pm
Cheers Shane
Hmm that's a point - might try lapping (using the drill method as before) but concentrate with the pin to the rear more. Will need to mark the location of the seat and nut to get them lined up. - next Tuesday's job :roll:
David L
PostPosted: Wed Oct 30, 2013 7:19 am
I've always done the lapping without a drill, and that's because ball joints don't go round in circles when on the car! I've always gone from 12 o'clock to 6, then 1 to 7, then 2 to 8 and keep working around.
Using a drill you can accidentally make it looser in some places more than others.
PostPosted: Wed Oct 30, 2013 2:23 pm
Thanks Irish - something to think on. Did some googling and came up with a couple threads on the Minispares Forum. - use fine paste only, lap by hand , even lap the face of the nut. One guy puts the shims under the lock washer and another no lock washer but loctite - might do both when I got them right.
David L
Users browsing this forum: rhaj and 90 guests
