It is currently Wed Jul 23, 2025 7:24 pm
PostPosted: Tue Oct 29, 2013 6:17 pm
Hey everyone
Just after an idea here - i have a couple of drum backing plates setup ready to install on my mini.
Ive noted you have to remove the rear outer hub but are the existing bearings reused / touched/ removed at all ? Should i replace the rear bearings ? Thinking of ordering them with the next UK shipment if need be
Whats the basic process ?
Thanks !
PostPosted: Tue Oct 29, 2013 8:25 pm
Yes the bearing will need to come off with the hub. They usually come off without a drama.
If they come off without a fight, and are carefully removed and replaced in the same order and without any dirt, then they will be perfectly fine.
If you need to remove the bearing with a puller or using a drift, then you should replace it.
PostPosted: Tue Oct 29, 2013 8:35 pm
I like to wash them in turps and repack them with new grease...
PostPosted: Wed Oct 30, 2013 3:57 pm
white spirit is the best thing to remove the old grease
PostPosted: Wed Oct 30, 2013 4:39 pm
Why is that Mick? What does white spirit offer?
I've always wondered why there is so much of it on the hardware shelves..
PostPosted: Wed Oct 30, 2013 5:40 pm
white spirits is turps....isnt it ?
Anyway ill grab some new rear bearings from minisport as they are cheap and might be needed.
PostPosted: Wed Oct 30, 2013 6:35 pm
probably... shops put both of them on the shelf so you think you need a bottle of each
Users browsing this forum: drmini in aust and 111 guests
